ilogic to change sheet name in drawing
14 REPLIES 14
Message 1 of 15
deffysalfauzi
606 Views, 14 Replies
Hi, help me. I would like to change my sheet name to be sequentially numbers as shown below. Thanks.
FYI,
Nomenclature :
RTU-385-001 - 385-Filter Support BT_Top 2:1
Note :
RTU-385 = .ipt > iproperties > project > stock number
<space>-<space> = separator
001,002,003,.... = sequentially numbers as sheet number (3 digit)
385-Filter Support BT_Top 2 = .ipt > iproperties > project > part number
:1,2,3,.... = sheet number
14 REPLIES 14
Message 2 of 15
Via I-logic vba or vb.net?
Via I-logic:
Public Sub main
	Dim a As Inventor.DrawingDocument = ThisDrawing.Document
	Dim sht As Inventor.Sheet
	Dim shts As Inventor.Sheets
	Dim c2 As Integer = 0
	For Each sht In a.Sheets
		c2=c2+1
		Dim d As Inventor.Document = sht.DrawingViews.Item(1).ReferencedDocumentDescriptor.ReferencedDocument
		Dim c1 As String = d.PropertySets.Item(3).Item("stock number").Value
		Dim c3 As String = d.PropertySets.Item(3).Item( "part number").Value
		sht.Name = c1 & "-" & "00" & c2 & c3 '& ":" & c2
	Next
End Sub
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Message 3 of 15
Wow thanks very much. How about 3 digit number, start from 001 to 999. Likes this one :
RTU-385-001
RTU-385-008
RTU-385-009
RTU-385-010
RTU-385-999
Message 4 of 15
Is the rest of the code fine for you, only the digits from 001 to 999!?
Arthur Knoors
Message 5 of 15
is this what you need then?
Public Sub Main
		c2=c2+1
		If c2<999 Then
			If c2<99 Then
				If c2<10 Then
		End If
				Else
		sht.Name = c1 & "-" & "0" & c2 & c3 '& ":" & c2
		End If
			Else
		sht.Name = c1 & "-" & "" & c2 & c3 '& ":" & c2
		End If
	Next
End Sub
Arthur Knoors
Message 6 of 15
Via I-logic:
Public Sub main
		c2=c2+1
	Next
End Sub
ilogic from sheet 1 to 15, different from the goal likes this :
RTU-385-008
RTU-385-009
RTU-385-010
RTU-385-999
Note :
RTU-385 = stock number
001,002,...,099,...,999 = sequentially numbers same as sheet number (3 digit)
385-Filter Support BT_Top 2 = part number
Message 7 of 15
Public Sub Main
		c2=c2+1
		If c2<999 Then
			If c2<99 Then
				If c2<10 Then
		End If
				Else
		End If
			Else
		End If
	Next
End Sub
result from ilogic :
can you change the code.
***Sorry, my English is not good enough
Message 8 of 15
This will finally do the trick:
Public Sub Main
		c2=c2+1
		If c2>0 And c2<9 Then
	ElseIf c2>99 And c2 <999
	ElseIf c2>9 And c2<99
	End If
	Next
End Sub
Arthur Knoors
Message 9 of 15
Public Sub Main
		c2=c2+1
	End If
	Next
End Sub
Sheet:9 ?
change to this ?
ElseIf c2>=9 And c2<99
Message 10 of 15
we come closer:
Public Sub Main
		c2=c2+1
		If c2>0 And c2<10 Then
	ElseIf c2>99 And c2 <1000
	ElseIf c2>9 And c2<100
	End If
	Next
End Sub
Arthur Knoors
Message 11 of 15
can you give a (space)-(space) like this " - " without quote between like this c2 & c3
c2 & " - " & c3
Message 12 of 15
Public Sub Main
		c2=c2+1
		sht.Name = c1 & " - " & "00" & c2 & " - " & c3 '& ":" & c2
		sht.Name = c1 & " - " & "" & c2& " - " & c3 '& ":" & c2
		sht.Name = c1 & " - " & "0" & c2& " - " & c3 '& ":" & c2
	End If
	Next
End Sub
Arthur Knoors
Message 13 of 15
Public Sub Main
		c2=c2+1
		sht.Name = c1 & "-" & "00" & c2 & " - " & c3 '& ":" & c2
		sht.Name = c1 & "-" & "" & c2 & " - " & c3 '& ":" & c2
		sht.Name = c1 & "-" & "0" & c2 & " - " & c3 '& ":" & c2
	End If
	Next
End Sub
Message 14 of 15
we come closer:
Public Sub Main
		c2=c2+1
	End If
	Next
End Sub
Based on this code, I changed and added a space between C2 and C3. thanks
Message 15 of 15
Thank you very much. Exported to AutoCAD so it looks like this.
