iLogic - set Exportparameter
Uwe_Lindner
Uwe_Lindner
Hallo Forum,
wie kann ich beim erstellen von benutzerdefinierten Parametern den Schalter für den Exportparameter setzen?
Wenn ich über eine Regel einen Parameter erzeuge, dann ist die Wahlbox zum Exportparameter leer.
bradeneuropeArthur
Hi @Uwe_Lindner
I don't understand what you mean!
could you please explain a little more in detail.
German is no problem for me but for the forum maybe it is..
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Sergio.D.Suárez
Hi, below is an example of a code that creates a custom parameter in a file.
I think the answer to what you ask is in the red line of the code
Dim ParamName As String = "A1"
ThisDoc.Document.ComponentDefinition.Parameters.UserParameters.AddByExpression(ParamName, "100", "mm")
oParam = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters.Item(ParamName)'get the parameter
oParam.ExposedAsProperty = True'export the paramter as an iProperty
oParam.CustomPropertyFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType'kNumberPropertyType
oParam.CustomPropertyFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision'kThreeDecimalPlacesPrecision
oParam.CustomPropertyFormat.ShowUnitsString=False
oParam.CustomPropertyFormat.ShowTrailingZeros = False
oParam.CustomPropertyFormat.ShowLeadingZeros = False
 I hope this helps greetings
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Uwe_Lindner
