Execute function Get name solid when select on solid in multi solid parts
ngocson8335
ngocson8335
Dear Expert,
I just create a Dockable Window and put a textbox on it. I want it automatically gets a solid name when I select on the solid. How can it execute the GET NAME SOLID Function instead of click on the button?
Here is the dockable window:
Many thanks
Ngoc Son
Autodesk User
Sergio.D.Suárez
Dim oSolid As Surfacebody= ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select SolidBody")
	If oSolid Is Nothing Then Exit Sub
MessageBox.Show(oSolid.Name)
Hi, try this code, I hope it helps with your problem
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
ngocson8335
With your code, I need a button to run this function?
I want to get the solid name without using the push button to start the function.
Thanks Sir
Ngoc Son
Autodesk User
ngocson8335
Hello Sir,
Can you help me?
Ngoc Son
Autodesk User
