I want my rule to set up Event triggers for itself from inside the rule. Is there a good way to do this?
Hi Tigerpirro,
You can copy the event triggers that are set in another file (a template for instance).
http://adndevblog.typepad.com/manufacturing/2015/01/add-external-ilogic-rule-to-event-trigger.html
my modified version of the example at that link is below. I set up external rules with event triggers in the templates, and then I have this "Copy Event Triggers rule" called from various other external rules as needed. Keep in mind, I repurposed the rule I found at the adndevblog, so there is likely some extra stuff in there that is not needed, etc. I never did go back through it and clean it up.
I hope this helps.
Curtis
Imports System.Collections.Generic 'code taken and modified from: 'http://adndevblog.typepad.com/manufacturing/2015/01/add-external-ilogic-rule-to-event-trigger.html Sub Main Trace.WriteLine("Event Driven Rules Copy", "iLogic") 'debug Dim oTemplateDoc As Document Dim oTemplate As String 'check file type If ThisApplication.ActiveEditDocument.DocumentType = kDrawingDocumentObject Then 'If ThisDoc.Document.DocumentType = kDrawingDocumentObject Then oTemplate = "\\server\departments\CAD\Inventor\Templates\Standard.idw" 'file to copy events from ElseIf ThisApplication.ActiveEditDocument.DocumentType = kPartDocumentObject Then 'ElseIf ThisDoc.Document.DocumentType = kPartDocumentObject Then oTemplate = "\\server\departments\CAD\Inventor\Templates\Standard.ipt" 'file to copy events from Else oTemplate = "\\server\departments\CAD\Inventor\Templates\Standard.iam" 'file to copy events from End If 'file to copy events to oInput = ThisApplication.ActiveEditDocument.FullFileName If oInput = "" Then 'catch a new file with no path Return End If 'open the template oTemplateDoc = ThisApplication.Documents.Open(oTemplate, False) CopyEventsToDocuments(oTemplateDoc) oTemplateDoc.Close End Sub Private Const m_ourGuid As String = "{2C540830-0723-455E-A8E2-891722EB4C3E}" Private savedEnabled As Boolean Dim oInput As String Public Sub CopyEventsToDocuments(ByVal sourceDoc As Document) Dim sourcePropSet As PropertySet = GetEventRulesPropertySet(sourceDoc) Dim inputs() As String = { oInput} Dim destinationFileNames As List(Of String) = New List(Of String)(inputs) If (destinationFileNames Is Nothing) Then Return savedEnabled = iLogicVb.Automation.RulesOnEventsEnabled iLogicVb.Automation.RulesOnEventsEnabled = False Try CopyEventsToAllDocuments(sourcePropSet, sourceDoc, destinationFileNames) Finally iLogicVb.Automation.RulesOnEventsEnabled = savedEnabled End Try End Sub Function GetEventRulesPropertySet(ByVal sourceDoc As Document) As PropertySet Try Return sourceDoc.PropertySets(m_ourGuid) Catch ex As Exception Return Nothing End Try End Function Function VerifyRulesPropertySet(ByVal propSet As PropertySet) As Boolean If (propSet Is Nothing) Then Return True ' See if any rules are internal instead of external. We can't copy those. For Each prop As Inventor.Property In propSet Dim strValue As String = prop.Value.ToString If (Not strValue.StartsWith("file://")) Then Return False Next Return True End Function Sub CopyEventsToAllDocuments(ByVal sourcePropSet As PropertySet, ByVal sourceDoc As Document, ByVal destinationFileNames As List(Of String)) For Each fileName As String In destinationFileNames If (String.Equals(sourceDoc.FullFileName, fileName)) Then Continue For CopyEventsToDocument(sourcePropSet, fileName) Next End Sub Sub CopyEventsToDocument(ByVal sourcePropSet As PropertySet, ByVal fileName As String) 'Dim doc As Document = FindOpenDocument(fileName) Dim openedHere As Boolean = False If (doc Is Nothing) Then doc = ThisApplication.Documents.Open(fileName, True) openedHere = True End If CopyEventsPropertySetToDocument(sourcePropSet, doc) iLogicVb.Automation.RulesOnEventsEnabled = savedEnabled End Sub Sub CopyEventsPropertySetToDocument(ByVal sourcePropSet As PropertySet, ByVal doc As Document) ' If an event-driven rules property set already exists, delete it. Dim oldPropSet As PropertySet = GetEventRulesPropertySet(doc) If (oldPropSet IsNot Nothing) Then oldPropSet.Delete() End If If (sourcePropSet Is Nothing OrElse sourcePropSet.Count = 0) Then Return Dim destPropSet As PropertySet = doc.PropertySets.Add("_iLogicEventsRules", m_ourGuid) For Each prop As Inventor.Property In sourcePropSet destPropSet.Add(prop.Value, prop.Name, prop.PropId) Next EnsureDocumentInterest(doc) End Sub Const iLogicId As String = "{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}" Sub EnsureDocumentInterest(ByVal doc As Document) If (ThisApplication.SoftwareVersion.Major < 15) Then Return ' Inventor 2010 or before If (DocumentHasiLogicInterest(doc)) Then Return Dim dataVersion As Integer = 20090512 Dim newInterest As DocumentInterest = doc.DocumentInterests.Add(iLogicId, "iLogic", DocumentInterestTypeEnum.kInterested, dataVersion, Nothing) End Sub Function DocumentHasiLogicInterest(ByVal doc As Document) As Boolean Dim interest As DocumentInterest = FindDocumentInterest(doc, iLogicId) If (interest IsNot Nothing) Then If (interest.InterestType = DocumentInterestTypeEnum.kInterested) Then Return True End If interest.Delete() End If Return False End Function Function FindDocumentInterest(ByVal doc As Document, ByVal clientId As String) As DocumentInterest For Each interest As DocumentInterest In doc.DocumentInterests If (String.Equals(interest.ClientId, clientId, StringComparison.OrdinalIgnoreCase)) Then Return interest End If Next Return Nothing End Function
@Curtis_Waguespack wrote:Hi Tigerpirro,
You can copy the event triggers that are set in another file (a templa...
Sorry to reply to an old post, but I can't get this to work properly. I get it to copy my 2 event triggers to the new file, but only one of them runs initially when it should. The other doesn't run. When I open the event triggers window, both rules are there. First (which runs as it should) runs on before save, and creates a flat pattern if it doesn't exist. The second runs (or should run) on iproperty change, and updates the material and thickness of the sheet metal part according to two custom iproperties.
BUT, if I open the event triggers window, and then press OK (without changing anything), then it works perfectly. If I just press cancel, it still doesn't run.
Any ideas what might cause this?
I didnt look at the code very carefully, but i would guess that it may not be increment the same type of triggers.
ie; if you have two triggers for before save, one needs to be 200 and the next needs to be 201. any additional ones would have to be 202, 203, 204, and so on.
Good luck.
When I place this rule in an event it doesn't work. I doesn't set the events properly, they are not named (the attached images shows it). When the event occurs I get the error message:
Event driven iLogic rule RunRule: Found no rule with name ""
(it only translated from the german warning so it might be different in detail)
Why does it not set the new events properly when this rule is event driven? It works if I fire it manually...
I have to add: I added this rule in an event in my template, so when I run it once manually, it will be in the current document. There it works once and then the error I descriped occurs...
