iLogic - Nicht verwendete Parameter bereinigen
Uwe_Lindner
Uwe_Lindner
Gibt es eine Möglichkeit mit der man über iLogic den Befehl zum bereinigen von nicht verwendeten Parametern absetzen kann?
bradeneuropeArthur
This will help you I hope?
https://forums.autodesk.com/t5/inventor-customization/delete-unused-parameters/td-p/7027159
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Sergio.D.Suárez
For Each oParam As Parameter In ThisDoc.Document.ComponentDefinition.Parameters
	If Not oParam.InUse Then
		on error resume next
		question = MessageBox.Show("Delete Parameter: " & oParam.Name  & "?", "Purge Unused Parameters", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
		If question = vbYes Then oParam.Delete()
Next
Hi, try this ilogic rule, I think it should work. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Uwe_Lindner
Gracias por la rápida respuesta - funciona bien
