Add up a custom iProperty called hours in sub assemlies or parts.
tracey
tracey
Hi, I have created a custom parameter called "Hours" in some parts and sub assemblies and populated the value.  I have used this type of rule before but it returns a value of 0 even though some of my parts and sub assemblies have the property added.  I am perplexed.   Anything obviously wrong?
Sub Main()
'Inventor.ComponentOccurrences'.
    ' Get the active assembly.
    Dim oAsmDoc As AssemblyDocument
    oAsmDoc = ThisApplication.ActiveDocument
    Dim oHours As Double
    Dim oCustomProps As PropertySet = oAsmDoc.PropertySets.Item("User Defined Properties")
    Dim oProperty As Inventor.Property
'Look for property "Total_Hours" this is only required at the top level.
        Try
'    'try to access the property Total_Hours
            oProperty = oCustomProps.Item("Total_Hours")
        Catch
'    'If failure, assume prop doesnt exist and create it
            oProperty = oCustomProps.Add("", "Total_Hours")
        End Try
        'Call the function that does the recursion.
    oHours = TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences)
    oProperty.Value = CDbl(oHours)
MsgBox(oHours)
    End Sub
Private Function TraverseAssembly(ByVal Occurrences As ComponentOccurrences) As Double
       For Each oOcc As ComponentOccurrence In Occurrences
        Try
            If oOcc.BOMStructure = BOMStructureEnum.kPhantomBOMStructure Or
                oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
            Else
         Dim oDoc As Document
        oDoc = oOcc.Definition.Document
         Dim oPropSet As PropertySet
         oPropSet = oDoc.PropertySets.Item("Design Tracking Properties")
        ' Get the total of this occurrence
        oHours += oPropSet.Item("Hours").Value
        ' Check to see if this occurrence represents a subassembly
        ' and recursively call this function to traverse through it.
        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
           oHours += TraverseAssembly(oOcc.Definition.Occurrences)
    Catch
    End Try
    Next
    iProperties.Value(Name, "Custom", "Total_Hours") = oHours
    Return oHours
End Function
'Thank you for your help!!
JhoelForshav
Hi @tracey ,
See code below
Sub Main()
        Try
        Catch
        End Try
MsgBox(oHours)
    End Sub
        Try
            If oOcc.BOMStructure = BOMStructureEnum.kPhantomBOMStructure Or _
            Else
		 '::::::::::::THIS IS IT:::::::::::::::::::::::::::::::::::::::::
         oPropSet = oDoc.PropertySets.Item("User Defined Properties") 'Changed to User defined props
    Catch
    End Try
    Next
    Return oHours
End Function
AlexFielder
Oh @tracey  - and there was me thinking I was the only person who needed to account for the time taken working on an Inventor assembly! Welcome to the "Management wants to know what's been taking so long" club!
Here's my old rule that counted Features and Parameters in parts. And Features, Occurrences, Parameters and Constraints in Assemblies:
https://github.com/AlexFielder/iLogic/blob/master/Modelling/RunFeatureCountonAssembly.iLogicVb (Linked here in case I update it)
Imports Inventor
Imports System.IO
Public Sub Main
If TypeOf ThisDoc.Document Is PartDocument Then
PartFeatureCount(ThisDoc)
Else
RunFeatureCount(ThisDoc.Document)
MessageBox.Show("Done!")
End Sub
Public Sub RunFeatureCount(ByVal oDoc as Inventor.Document)
	Dim oAssy As inventor.AssemblyDocument
	Dim oSubDoc as Inventor.Document
	If oDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
		oAssy = CType(oDoc,AssemblyDocument)
		AssemblyFeatureCount(oAssy)
		For Each oComp In oAssy.ReferencedDocuments
			'oSubDoc = CType(oComp.Definition.Document,Document)
			'MessageBox.Show(oSubDoc.File.FullFileName)
			If oComp.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
				'run FeatureCount and then call RunFeatureCount to recurse the assembly structure
				'iLogicVb.RunExternalRule("FEATURECOUNT")
				FeatureCount(oComp)
				RunFeatureCount(oComp)
			Else
				'run FeatureCount
				FeatureCount(oComp)
		Next
	ElseIf oDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
		FeatureCount(oDoc)
End Sub
Sub FeatureCount(ByVal oDoc as Inventor.Document)
	Try
	Dim SaveRequired As Boolean = False
	'uncomment for debugging purposes!
	'MessageBox.Show(DocName)
		If TypeOf oDoc Is PartDocument Then
			If Not oDoc.File.FullFileName.Contains("Content") And Not oDoc.File.fullfilename.contains("FACILITY") And Not oDoc.File.fullfilename.contains("Imported Components") Then 'skip CC and FACILITY files
				Dim PartDocName As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.DisplayName) & ":1"
				Dim oFeats as PartFeatures = oDoc.ComponentDefinition.Features
				Dim oParams as Parameters = oDoc.ComponentDefinition.Parameters
				Try
					If Not iProperties.Value(PartDocName,"Custom", "FEATURECOUNT") = oFeats.Count Then 'or update it
						SaveRequired = True
					'MessageBox.Show("Feature Count for this part is: " & oFeats.Count, "FEATURECOUNT")
					If Not iProperties.Value(PartDocName,"Custom","PARAMETERCOUNT") = oParams.Count Then 'or update it
						SaveRequired = True
					'MessageBox.Show("Parameter Count for " & oDoc.File.fullfilename &" is: " & oParams.Count, "PARAMETERCOUNT")
					If SaveRequired Then
						'oDoc.Save 'try to save the file.
				Catch
					Exit Sub
				End Try
		ElseIf TypeOf oDoc Is AssemblyDocument Then
				Dim DocName As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.DisplayName) & ":1"
				Dim oFeats as Features = oDoc.ComponentDefinition.Features
				Dim Occs as ComponentOccurrences = oDoc.ComponentDefinition.Occurrences
				'Dim oConstraints as Constraints = oDoc.ComponentDefinition.Constraints
				Try
					If Not iProperties.Value(DocName,"Custom", "FEATURECOUNT") = oFeats.Count Then
						SaveRequired = True
					'MessageBox.Show("Feature Count for this assembly is: " & oFeats.Count, "FEATURECOUNT")
					If Not iProperties.Value(DocName, "Custom", "OCCURRENCECOUNT") = Occs.Count Then
						SaveRequired = True
					'MessageBox.Show("Occurrence Count for " & oDoc.File.fullfilename & " is: " & Occs.Count, "OCCURRENCECOUNT")
					If Not iProperties.Value(DocName, "Custom","PARAMETERCOUNT") = oParams.Count Then
						iProperties.Value(DocName, "Custom", "PARAMETERCOUNT") = oParams.Count
						SaveRequired = True
					'MessageBox.Show("Parameter Count for this part is: " & oDoc.ComponentDefinition.Constraints.Count, "PARAMETERCOUNT")
					If Not iProperties.Value(DocName, "Custom","CONSTRAINTCOUNT") = oDoc.ComponentDefinition.Constraints.Count Then
						iProperties.Value(DocName,"Custom", "CONSTRAINTCOUNT") = oDoc.ComponentDefinition.Constraints.Count
						SaveRequired = True
					'MessageBox.Show("Constraint Count for Assembly " & DocName & " is: " & oDoc.ComponentDefinition.Constraints.Count, "CONSTRAINTCOUNT")
				Catch
					'creates any missing iProperties.
					'oDoc.Save 'saves the assembly
					Exit Sub
				End Try
	Catch ex As Exception
		'MessageBox.Show("The error is: " & ex.Message & vbCrLf & ex.StackTrace,oDoc.DisplayName)
	End Try
End Sub
Sub PartFeatureCount(ByVal oDoc)
	Try
			Dim oFeats as PartFeatures = oDoc.Document.ComponentDefinition.Features
			Dim oParams as Parameters = oDoc.Document.ComponentDefinition.Parameters
			Try
				'may need to save the file when we're done, hence the boolean check
				If Not iProperties.Value("Custom", "FEATURECOUNT") = oFeats.Count Then
					SaveRequired = True
				If Not iProperties.Value("Custom","PARAMETERCOUNT") = oParams.Count Then
					SaveRequired = True
				'MessageBox.Show("Parameter Count for " & oDoc.Document.File.fullfilename &" is: " & oParams.Count, "PARAMETERCOUNT")
			Catch
				'definitely need to save the file!
				'oDoc.Close 'try to close the file - on a vaulted file this will fire the check-in dialogue.
			End Try
		'MessageBox.Show("The error is: " & ex.Message & vbCrLf & ex.StackTrace)
	End Try
End Sub
Sub AssemblyFeatureCount(ByVal oDoc)
	Try
		'Dim DocName As String = oDoc.DisplayName
			Try
					SaveRequired = True
				If Not iProperties.Value("Custom", "OCCURRENCECOUNT") = Occs.Count Then
					SaveRequired = True
					iProperties.Value("Custom", "PARAMETERCOUNT") = oParams.Count
					SaveRequired = True
				If Not iProperties.Value("Custom","CONSTRAINTCOUNT") = oDoc.ComponentDefinition.Constraints.Count Then
					iProperties.Value("Custom", "CONSTRAINTCOUNT") = oDoc.ComponentDefinition.Constraints.Count
					SaveRequired = True
			Catch
				Exit Sub
			End Try
	End Try
End Sub
tracey
Thank you!!! This lead to a good read of Inventor help on the subject too.  This works perfectly.Smiley Happy
Thank you once again
tracey
Thank you Alex, that is quite a rule!!  My hours custom iproperty is an estimate of the build cost per sub assembly which I will input into the parameter where needed.  I have a summary document A4, which give a picture, totals for weight, cost and build hours as a sales document.  I LOVE automation!!!
I am about to run your rule!
AlexFielder
How did you get on @tracey ?
