iLogic rule to include/exclude derived parameter in all parts from an assembly
israel.paquette
Message 1 of 10
israel.paquette
Hi, I'm currently working on an assembly that contain over 300 parts.
Almost each of those parts contain a derived component.
I need to include a parameter in each derived components in all parts.
So I'm trying to write an iLogic rule that I will run from the assembly and will include that specific parameter in each derived components of all parts.
I'm using this rue that I found on DevBlog. It's working perfectly if I run it from the specific part that contain the derived component but I can't find the proper way to run it from my main assembly.
'If ThisApplication.ActiveDocument.DocumentType <> kPartDocumentObject Then
'    MsgBox("Make a Part Document the active document")
'End If
Dim oDerPart As PartDocument
oDerPart = ThisApplication.ActiveDocument
Dim oDerPartComp As DerivedPartComponent
If oDerPart.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Count < 1 Then
    MsgBox("No Derived Part Components in this part")
oDerPartComp = oDerPart.ComponentDefinition.ReferenceComponents.DerivedPartComponents(1)
Dim oDerivedPartDef As DerivedPartUniformScaleDef
oDerivedPartDef = oDerPartComp.Definition
Dim oDerEntity As DerivedPartEntity
For Each oDerEntity In oDerivedPartDef.Parameters
    If (oDerEntity.ReferencedEntity.Name = "BLADE_ATTACK_ANGLE") Then
        oDerEntity.IncludeEntity = True
        Exit For
Next
'Set Definition back, so DerivedPart Document is updated
oDerPartComp.Definition = oDerivedPartDef
This is my try to run it from the assembly but it's not doing anything...
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
Dim oDoc As Document = ThisDoc.Document
Dim oCompDef As Inventor.ComponentDefinition = oDoc.ComponentDefinition
Dim oCompOcc As Inventor.ComponentOccurrence
On Error Resume Next
For Each oOccurrence In oCompDef.Occurrences
	Parameter.Quiet = True
' **** CHANGE TO DO ****
'	INCLUDE A DERIVED COMPONENT PARAMETER
	oCompOcc = oOccurrence.Definition
	oDerPartComp = oCompOcc.ComponentDefinition.ReferenceComponents.DerivedPartComponents(1)
	    Exit For
	Next
' **** END ****
Next
InventorVb.DocumentUpdate()
I hope that someone will be able to correct my code! Smiley Happy
Best regards
Replies (9)
Message 2 of 10
lmc.engineering
Hi @israel.paquette
This should work for you
' Check whether open document is an assembly
oDoc = ThisDoc.ModelDocument
If oDoc.DocumentType = kPartDocumentObject Then
MessageBox.Show("This rule can only be run in an assembly file - exiting rule", "iLogic")
Return
Dim doc As Document = ThisDoc.Document
For Each doc In oDoc.AllReferencedDocuments
	If doc.DocumentType = 12290 Then 'part file
		Dim oDPComp As DerivedPartComponent
		Dim oDPComps As DerivedPartComponents
		oDPComps = doc.ComponentDefinition.ReferenceComponents.DerivedPartComponents
			For x = 1 To oDPComps.Count
				oDPComp = oDPComps.Item(x)
				Dim oDPDef As DerivedPartDefinition = oDPComp.Definition
				Dim oDPEnts As DerivedPartEntities = oDPDef.Parameters
				Dim oDPEnt As DerivedPartEntity
					For Each oDPEnt In oDPEnts
						If oDPEnt.ReferencedEntity.Name = "Test" Then ' Add your parameter name here!
							oDPEnt.IncludeEntity = True
					Next
			oDPComp.Definition = oDPDef
			Next
Next
Regards
Message 3 of 10
israel.paquette
Thanks for your help.
Unfortunately, I can't that rule.
I created a new rule in my assembly and pasted your code in it. I, of course, edited the parameter name.
When I try to run it, I obtain that error message:
System.Runtime.InteropServices.COMException (0x80004005): Erreur non spécifiée (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.DerivedPartComponent.set_Definition(DerivedPartDefinition )
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Maybe I'm doing something wrong!
Message 4 of 10
Sergio.D.Suárez
Hello, try this rule, executed in an assembly
Dim openDoc As AssemblyDocument
openDoc = ThisDoc.Document
Dim doc As Document
For Each doc In openDoc.AllReferencedDocuments
	oDerPartComp = doc.ComponentDefinition.ReferenceComponents.DerivedPartComponents(1)
	        Exit For
	Next
Next
Parameter.UpdateAfterChange = True
iLogicVb.UpdateWhenDone = True
 I hope it will work for you and help you solve your problem
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 5 of 10
lmc.engineering
The issues lies with the derived part definition so I have modified the way it is defined. Maybe you can try this again:
Return
				Dim oDPDef As DerivedPartUniformScaleDef = oDPComp.Definition ' Changed this line
						If oDPEnt.ReferencedEntity.Name = "test1" Then ' Add your parameter name here!
							Exit For
					Next
			Next
Next
Message 6 of 10
israel.paquette
Thank you very much to you guys!
Both solutions worked perfectly!
Message 7 of 10
forbillian
Hi Sergio,
This was very helpful.  Thankyou.
One question,  I have been trying to run the same rule but only searching for
derived parts that are contained in parts that aren't reference.  I have tried adjusting your code with this (see below), but I am still getting every derived part back - & I want to ignore derived parts in reference parts.  Any advice?
If doc.Component.Defintion.BOMStructure = BOMStructureEnum.kDefaultBOMStructure Then
Thanks Sergio
Message 8 of 10
forbillian
Hi @lmc.engineering ,
Is there a way - when looping through referenced docs to locate derived parts - to ignore any referenced docs that have a Reference BOM State.
I have tried something like this but I still get derived parts called which are located in referenced parts - I only want the rule to apply to derived parts contained within parts that appear in the BOM - if that makes sense?:
If oDoc.Component.Defintion.BOMStructure = BOMStructureEnum.kDefaultBOMStructure Then
Thanks @lmc.engineering
Message 9 of 10
lmc.engineering
Hi @forbillian
I think the easiest way to do this is change the way we go through the assembly, from AllReferencedDocuments to recursively looking at the ComponentOccurrences. The reason being is that the document reference only picks up on the BOM structure assigned to the file itself and not any assembly level overrides. I've not tested the below hugely but hopefully it works for you
Sub Main()
	Return
	Dim doc As AssemblyDocument = ThisDoc.Document
	Dim paramName As String = "testparam" ' Your parameter name
	TraverseAssembly(doc.ComponentDefinition.Occurrences,paramName)
End Sub
Sub TraverseAssembly(Occurrences As ComponentOccurrences,paramName As String)
	Dim oOcc As ComponentOccurrence
	For Each oOcc In Occurrences
		If oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then Continue For ' Skips all referenced components
			If TypeOf oOcc.Definition.Document Is AssemblyDocument Then
				TraverseAssembly(oOcc.SubOccurrences,paramName)
			Else
				oDPComps = oOcc.Definition.ReferenceComponents.DerivedPartComponents
							If oDPEnt.ReferencedEntity.Name = paramName Then
								Exit For
						Next
				Next
	Next
End Sub
Message 10 of 10
forbillian
Thanks you so much @lmc.engineering  for this code.
I have used your previous code to run another rule (see my rudimentary attempt below) which returns all parts, assemblies, derived parts & derived assemblies that are contained within a top GA Assembly file & BOM.
Just to explain  we use derived parts & derived assemblies for our machining method, but the disadvantage of this approach is that the derived parts/assemblies aren't visible in the TOP LEVEL BOM.
1.  I am having difficulties with my DerivedAssemblies rule (the DerivedParts rule seems to work) but having problems getting all derived assemblies contained in parts at lower levels
2.  I also need to be able to access parts & assemblies contained within any DerivedAssembly
Anyway I am hoping when you see my code below there you may find some obvious flaws or methods to streamline what I am trying to achieve.
'ITERATE THROUGH ALL ITEMS & RETURN ALL BOM PARTS, ASSEMBLIES INLCUDING DERIVED PARTS & DERIVED ASSEMBLIES
Sub Main ReturnPartsAssembliesDerived()
	    Dim oAsmDoc As AssemblyDocument
        oAsmDoc = ThisApplication.ActiveDocument
		'LOOP THROUGH STD PARTS & ASSEMBLIES
                    Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1)
		'LOOP THROUGH DERIVED PARTS
		    Call TraverseAssembly1(oAsmDoc.ComponentDefinition.Occurrences, 1)
		''LOOP THROUGH DERIVED ASSEMBLIES
		    Call TraverseAssembly2(oAsmDoc.ComponentDefinition.Occurrences, 1)
End Sub
'NORMAL PARTS & ASSEMBLIES RULE
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer) Dim oOcc As ComponentOccurrence Dim i As Integer i = 1 For Each oOcc In Occurrences Dim oBrowserNode As String oBrowserNode = oOcc.Name If oOcc.BOMStructure = 51970 Then '............................................................................. MsgBox(oOcc.Name) 'RETURNS ALL PARTS & ASSEMBLIES AT THE FIRST Level '............................................................................. If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then 'RETURNS ALL PARTS & ASSEMBLIES AT NEXT LEVEL Call TraverseAssembly(oOcc.SubOccurrences, Level + 1) Else End If End If Next oOcc End Sub 'DERIVED PARTS RULE Sub TraverseAssembly1(Occurrences As ComponentOccurrences,Level As Integer) Dim oOcc As ComponentOccurrence Dim i As Integer i = 1 For Each oOcc In Occurrences Dim oBrowserNode As String oBrowserNode = oOcc.Name If oOcc.BOMStructure = 51970 Then If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then Call TraverseAssembly(oOcc.SubOccurrences, Level + 1) Else Dim oDPComp As DerivedPartComponent Dim oDPComps As DerivedPartComponents oDPComps = oOcc.Definition.ReferenceComponents.DerivedPartComponents For x = 1 To oDPComps.Count oDPComp = oDPComps.Item(x) Dim oDPDef As DerivedPartUniformScaleDef = oDPComp.Definition If (TypeOf oDPDef Is DerivedPartUniformScaleDef) Then Dim oDerPartUScaleDef As DerivedPartUniformScaleDef oDerPartUScaleDef = oDPDef 'THIS CONDITION IGNORES ANY MIRRORED VERSIONS OF DERIVED PARTS If oDerPartUScaleDef.MirrorPlane = 27396 Then '............................................................................. MsgBox(oDPComp.Name) 'RETURNS ALL DERIVED PARTS '.............................................................................. End If oDPComp.Definition = oDPDef End If Next End If End If Next oOcc End Sub 'DERIVED ASSEMBLIES RULE Sub TraverseAssembly2(Occurrences As ComponentOccurrences,Level As Integer) Dim oOcc As ComponentOccurrence Dim i As Integer i = 1 For Each oOcc In Occurrences Dim oBrowserNode As String oBrowserNode = oOcc.Name If oOcc.BOMStructure = 51970 Then If TypeOf oOcc.Definition.Document Is AssemblyDocument Then TraverseAssembly2(oOcc.SubOccurrences, Level + 1) Else On Error Resume Next Dim oDAComp As DerivedAssemblyComponent Dim oDAComps As DerivedAssemblyComponents oDAComps = oOcc.Definition.ReferenceComponents.DerivedAssemblyComponents For x = 1 To oDAComps.Count oDAComp = oDAComps.Item(x) '............................................................................. MsgBox(oDAComp.Name) 'RETURNS ALL DERIVED ASSEMBLIES '.............................................................................. oDAComp.Definition = oDADef Next End If End If Next oOcc End Sub
