Hi
keeping things organised, i moved some code to a Public Class. I instantiate the application and pass in the document being used but im hitting an issue.
iProperties.Value(ComponentODocName, SetName, PropertyName) obviously works in sub Main() level but not in Class level. Ive tried adding the doc to the front but nothing.
what is the magic code required for this in a class?
thanks
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Hi guys. I believe this is like most cases where you want to be able to use 'Rule Objects' within other resources. I believe the 'iProperties' object is essentially a local variable of type Autodesk.iLogic.Interfaces.IiProperties Interface, which has already been assigned a value for us behind the scenes. To use it else where, we would usually need to 'pass' that iProperties variable to the other resource, one way or another. You could have local variable within your other Class with its Type set to Autodesk.iLogic.Interfaces.IiProperties, then set that 'input' object as its value whichever way you want, then you should be able to use that local variable. But I believe there may be at least one or more other more base iLogic objects that could be sent to 'another' resource that would provide a broader or more dynamic benefit, such as the iLogicVb or InventorVb objects (both are the same thing). You can use its CreateObjectProvider to create an IStandardObjectProvider, which can then be used as a basis for most of the other common and uniquely iLogic objects used in standard snippets.
Wesley Crihfield
(Not an Autodesk Employee)
I don't do ilogic that often, I'm more a vb guy and while they are similar, they are not.
It's not a biggie, I just ditched my class and promoted my functions up a level.
Thanks for replying
Nacho
Programming a addin gives you more flexibility and more possibilities. I think ilogic is meant to be used for product configurations....
Arthur Knoors
