I have a problem.
I use drawing template with ilogic rules which copy parameters of linked model into drawing and then into the title block. For example:
Dim openDoc As Document openDoc = ThisDoc.Document Dim docFile As Document If ThisDoc.ModelDocument IsNot Nothing Then docFile = ThisDoc.ModelDocument Else Return End If Dim FNamePos As Long FNamePos = InStrRev(docFile.FullFileName, "\", -1) Dim docFName As String docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos) VyberM = iProperties.Material(docFName)
In docFName is saved the path to linked model file. But when model file is assembly with another level of detail representation than "main", the iLogic rule does not work. Is there any possibility to make the rule working with another level of representation? Or it is possible to make such a rule, which detects another level of detail representation than "main" in linked model and write error message?
Thanks for helping 🙂
It should work just fine using the file names. iProperties and parameters are stored in the master document, not any LODs.
Seeing more complete code would be cool.
There is full code of rule that rewrites parameters from model to drawing
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 29329 StartFragment: 314 EndFragment: 29297 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
trigger = iTrigger0 'Definuje otevřený dokument Dim openDoc As Document 'Prvni spusteni: 1 pravda, 0 nepravda openDoc = ThisDoc.Document 'Zjistí soubor modelu, na který se odkazuje výkres Dim docFile As Document If ThisDoc.ModelDocument IsNot Nothing Then docFile = ThisDoc.ModelDocument Else Return End If 'format model file name Dim FNamePos As Long FNamePos = InStrRev(docFile.FullFileName, "\", -1) Dim docFName As String docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos) 'define the property set customPropertySet = docFile.PropertySets.Item("Inventor User Defined Properties") 'look for the custom propety and add it if not found Try prop = customPropertySet.Item("VyberM") Catch customPropertySet.Add("", "VyberM") End Try 'get total area of model 'start radio box with questions 'napřed přepsání hodnot z modelu do razítka Datum_zmeny_1 = iProperties.Value(docFName, "Custom", "Datum změny 1") Datum_zmeny_2 = iProperties.Value(docFName, "Custom", "Datum změny 2") Datum_zmeny_3 = iProperties.Value(docFName, "Custom", "Datum změny 3") Datum_zmeny_4 = iProperties.Value(docFName, "Custom", "Datum změny 4") Index_zmeny_1 = iProperties.Value(docFName, "Custom", "Index změny 1") Index_zmeny_2 = iProperties.Value(docFName, "Custom", "Index změny 2") Index_zmeny_3 = iProperties.Value(docFName, "Custom", "Index změny 3") Index_zmeny_4 = iProperties.Value(docFName, "Custom", "Index změny 4") Zmena_1 = iProperties.Value(docFName, "Custom", "Změna 1") Zmena_2 = iProperties.Value(docFName, "Custom", "Změna 2") Zmena_3 = iProperties.Value(docFName, "Custom", "Změna 3") Zmena_4 = iProperties.Value(docFName, "Custom", "Změna 4") Nahrazuje = iProperties.Value(docFName, "Custom", "Nahrazuje") Norma_PU = iProperties.Value(docFName, "Custom", "Norma PÚ") Nazev_Rozmer = iProperties.Value(docFName, "Custom", "Název-Rozměr") If Nazev_Rozmer <> Sestava Then If Nazev_Rozmer <> SVAŘENEC Then iProperties.Value(docFName, "Custom", "Materiál") = Materiál End If End If Materiál = iProperties.Value(docFName, "Custom", "Materiál") Polotovar = iProperties.Value(docFName, "Custom", "Polotovar") Povrchova_uprava = iProperties.Value(docFName, "Custom", "Povrchová úprava") Pozice_v_sestave = iProperties.Value(docFName, "Custom", "Pozice v sestavě") Poznamka_PU = iProperties.Value(docFName, "Custom", "Poznámka-PÚ")
It works even if model doesnt have the same parameters as it is written in this rule. But it doesnt work with assembly, that uses another LOD than main.
And there is the rule, which rewrites parameters of model by the parameters of drawing. In the title block, parameters of model are used. Every parameter there is text parameter.
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 30086 StartFragment: 314 EndFragment: 30054 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
'Definuje otevřený dokument Dim openDoc As Document openDoc = ThisDoc.Document 'Zjistí soubor modelu, na který se odkazuje výkres Dim docFile As Document If ThisDoc.ModelDocument IsNot Nothing Then docFile = ThisDoc.ModelDocument Else Return End If 'format model file name Dim FNamePos As Long FNamePos = InStrRev(docFile.FullFileName, "\", -1) Dim docFName As String docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos) 'define the property set customPropertySet = docFile.PropertySets.Item("Inventor User Defined Properties") 'look for the custom propety and add it if not found Try prop = customPropertySet.Item("VyberM") Catch customPropertySet.Add("", "VyberM") End Try iProperties.Value(docFName, "Custom", "VyberM") = VyberM iProperties.Material(docFName) = VyberM iProperties.Value(docFName, "Project", "Part number") = Cislosoucasti iProperties.Value(docFName, "Summary", "Title") = Nazev 'Datum změny iProperties.Value(docFName, "Custom", "Datum změny 1") = Datum_zmeny_1 iProperties.Value(docFName, "Custom", "Datum změny 2") = Datum_zmeny_2 iProperties.Value(docFName, "Custom", "Datum změny 3") = Datum_zmeny_3 iProperties.Value(docFName, "Custom", "Datum změny 4") = Datum_zmeny_4 'Index změny iProperties.Value(docFName, "Custom", "Index změny 1") = Index_zmeny_1 iProperties.Value(docFName, "Custom", "Index změny 2") = Index_zmeny_2 iProperties.Value(docFName, "Custom", "Index změny 3") = Index_zmeny_3 iProperties.Value(docFName, "Custom", "Index změny 4") = Index_zmeny_4 'Změna iProperties.Value(docFName, "Custom", "Změna 1") = Zmena_1 iProperties.Value(docFName, "Custom", "Změna 2") = Zmena_2 iProperties.Value(docFName, "Custom", "Změna 3") = Zmena_3 iProperties.Value(docFName, "Custom", "Změna 4") = Zmena_4 iProperties.Value(docFName, "Custom", "Materiál") = Materiál iProperties.Value(docFName, "Custom", "Nahrazuje") = Nahrazuje iProperties.Value(docFName, "Custom", "Norma PÚ") = Norma_PU iProperties.Value(docFName, "Custom", "Název-Rozměr") = Nazev_Rozmer iProperties.Value(docFName, "Custom", "Polotovar") = Polotovar iProperties.Value(docFName, "Custom", "Povrchová úprava") = Povrchova_uprava iProperties.Value(docFName, "Custom", "Pozice v sestavě") = Pozice_v_sestave iProperties.Value(docFName, "Custom", "Poznámka-PÚ") = Poznamka_PU
Thank you for helping me.
Hi MechMachineMan,
I had similar problem. What I suggest you is to have in your sheet View in which you have Main level of detail representation. Instead of defining the ModelDocument by
define it using the View. Basically what I am doing is to: If the model document is assembly, chech the level of detail represenatiton. If main view has different level of detail representation, check all views with whe same model on the sheet. If there is view which has the main level of detail representation, use it for defining the model document. If there is no such view, create it outside of the area of sheet border.
There is my code:
If ThisDoc.Document.DocumentType = kDrawingDocumentObject Then 'Ověření, zda typ dokumentu je výkres - vhodné pro externí pravidla Else MessageBox.Show("Lze spustit pouze v otevřeném výkrese",iLogicVb.RuleName,MessageBoxButtons.OK,MessageBoxIcon.Exclamation) Exit Sub End If 'iLogicVb.RunRule("Aktualizace spolecnych iVlastnosti modelu na zaklade vykresu") Dim oDoc As DrawingDocument 'Definování dokumentu jako dokumentu výkresu oDoc = ThisApplication.ActiveDocument 'dokument = aktivní dokument Dim oSheet As Sheet = oDoc.ActiveSheet 'list = aktivní list Dim oView As DrawingView oView = oSheet.DrawingViews(1) OrigModel = oView.ReferencedDocumentDescriptor.ReferencedDocument 'Model hlavního pohledu Dim Hlavnipohled As Boolean = False 'Slouží pro určení, zda list má pohled s modelem hlavního pohledu, který je v úrovni detailu hlavní (u sestavy) - nebo který lze použít pro zapisování ivlastnosti (u součásti) If OrigModel.DocumentType = 12291 'Pokud je model hlavního pohledu sestava, tak: ActLOD = oView.ActiveLevelOfDetailRepresentation 'Definování úrovně detailu hlavního pohledu 'MessageBox.Show(ActLOD,"Úroveň detailu") 'MessageBox.Show("Spravně","Ilogic") If ActLOD <> "Main" Then 'Pokud je uroven detailu hlavního pohledu jiná než hlavní: Hlavnipohled = False For Each oView2 In oSheet.DrawingViews 'Zjisti, zda se na listu nenachází pohled, kde je vložen model hlavního pohledu, ale v úrovni detailu hlavní If oView2.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName = OrigModel.FullFileName 'prováděj pouze pro pohledy se stejným dokumentem jako s originálním pohledem ActLOD = oView2.ActiveLevelOfDetailRepresentation 'Uroven detailu prave porovnávaneho pohledu If ActLOD = "Hlavní" Then 'Pokud je uroven detailu prave porovnavaneho pohledu hlavní, tak: oView = oView2 'Definuj pohled pro zapisování iVlastností jako pravě porovnavany pohled Hlavnipohled = True 'Nyní je definovaný pohled, který lze použít pro definování iVlastností End If End If Next End If Else Hlavnipohled = True 'Pokud je model hlavního pohledu jiný než sestava, lze hlavní pohled použít pro zapisování iVlastností End If 'MessageBox.Show(Hlavnipohled,"Hlavní pohled: ") If Hlavnipohled = False 'Pokud platí, je ve výkrese pohled s modelem hlavního pohledu, který má hlavní úroveň detailu 'MessageBox.Show("Chyba","Ilogic") Dim oViewLoc As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(50, 50) 'Definice bodu vložení pohledu oViewNovy = oSheet.DrawingViews.AddBaseView(OrigModel, oViewLoc, 1, ViewOrientationTypeEnum.kDefaultViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle) 'Definice pohledu NovyLOD = oViewNovy.ActiveLevelOfDetailRepresentation 'Uroven detailu nově vloženého pohledu Dim nejvetsirozmer As Double 'Určení, zda je šířka vyšší než výška If oViewNovy.Width > oViewNovy.Height nejvetsirozmer = oViewNovy.Width Else nejvetsirozmer = oViewNovy.Height End If oViewNovy.Scale = 10/nejvetsirozmer 'určení měřítka pohledu If NovyLOD <> "Hlavní" 'Pokud je uroven detailu nově vloženého pohledu jiná než hlavní, přepni ji na hlavní oViewNovy.ActiveLevelOfDetailRepresentation = "Hlavní" End If oView = oViewNovy 'Pohled pro zapisování je nově vložený pohled Else 'Zde se vklada pohled s modelem hlavního pohledu, který ale má hlavní úroveň detailu End If 'Konec kodu pro kompatibilitu s urovněmi detailů______________________________________________________________________________________________________________________________ Dim oModelDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument 'definování dokumentu modelu jako modelu
