12:44 AM
Hi All,
I have a illogic script that works ok all it does is allow the user to update Iproperties but I now need to change a custom Ipropertiescall manufacturer to a drop down combo box.
I have found that I can do this by setting a parameter in the model and linking it in a rule. BUT the problem is I need to use this on parts that don't have this parameter set up on it.
there is 2 ways I think I can overcome this
1, I can run a rule that builds the parameter and then I can use it
2, code a combo box in the illogic and have the options held in the form? ( don't know if this 100% possible)
can anyone help
thank you in advance
