Object Reference Not Set Error - When Running iLogic Code
I have an iLogic rule which works fine on my PC, but whenever i jump onto a different code and try to run the code i get the message:
Error in code:....
Object Reference not set to an instance of an object
What are common issues that cause this, can someone list them?
bradeneuropeArthur
Can you upload the code as text?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
