Add If and Then to this drawing sheet naming iLogic Code
Message 1 of 9
Hey,
I have been using this code below, i did not create it, but i am wishing to add If and Then statement to it, but i have no idea where to start, is someone able to re-write this to include those statements
SyntaxEditor Code Snippet
Sub Main()
'Purpose: Push file name to sheet name'21-Sept-16
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oDrawingView As DrawingView
'Iterate through sheets
For Each oSheet In oDoc.Sheets
    'Grab the first drawing view on the sheet
    oDrawingView = oSheet.DrawingViews(1)
    'Grab the model of the first drawing view
    oModel = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
    'Grab the custom iproperty of the first drawing view model
    oModel1 = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
    o_iProp = iProperties.Value(oModel1, "Custom", "RevisionUK")
    'set sheet name to filename and custom iprop from model
    oSheet.Name = System.IO.Path.GetFileNameWithoutExtension(oModel.FullFileName)& " - " & o_iProp
End Sub
Replies (8)
Message 2 of 9
jletcher
Going to need more information..
Like what do you want the "If and Then" statement to do?
Message 3 of 9
Im having an issue with running the code on another pc and wondering if i give more detail in the code it may work?
Message 4 of 9
jletcher
I don't think adding a "if then" is going to do anything for you.
What are the issues on other machine?
Message 5 of 9
I get the error on others pc that Object reference is not set to an instance of an object? Any ideas why? Works fine on my machine
Message 6 of 9
jletcher
Are you using the same drawing?
Message 7 of 9
Yes,
all drawings work on mine, but the same ones do not work on other machines.
Message 8 of 9
jletcher
It errors right off the bat for me is there more to this?
there is a "For" statement but "Next"
Message 9 of 9
Curtis_Waguespack
Hi Grant.ParryGS9ZQ,
There are many people that work to keep the forum tidy, so please try not to create duplicate/redundant postings, as it spreads resources thin and makes future search results for similar issues fragmented and less effective. If you do determine that it best to create duplicate/redundant postings though, please take the time to provide links to them.
duplicate/redundant postings:
https://forums.autodesk.com/t5/inventor-forum/object-reference-not-set-error-when-running-ilogic-cod...
https://forums.autodesk.com/t5/inventor-customization/ilogic-rule-object-reference-not-set-to-an-ins...
Also in the future, for programming questions it's generally better to use the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
With all of that in mind for the future, let's get back to the issue:
A couple of questions:
  • Do the other machines have Windows set up to show file extensions? I think this might cause this issues you are seeing, if they are not showing file extensions.
  • On the other machines is the file saved, meaning does it have a file name and path, or are you running it from a new file created from a template that has not yet been saved. Based on the code snippet, that would be one cause of this issue.
  • Another cause would be a file that does not have a referenced model. For instance one with no drawing view.
Edit: I see the last 2 questions have been answered as I was typing.
I hope this helps.
Curtis
