Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
iLogic form API access
4 REPLIES 4
549 Views, 4 Replies
Is is possible to access the iLogic form properties of a parameter through an iLogic rule?
I wish to change the 'Allow Custom Values' property on "Inlet O/D" parameter based on the value of another parameter.
For example, in super high pseudo code:
If tfINLET_OD = True Then
        myForm.Parameter("INLET_OD").Properties.AllowCustomValues = True
Else
       myForm.Parameter("INLET_OD").Properties.AllowCustomValues = False
End If
4 REPLIES 4
bradeneuropeArthur
Think this is not supported. I have searched for a while too.
I am curious of the result.
This is one of the disadvantages of I logic.
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
philip1009
Changing properties of Forms is not possible with iLogic, however, you may have seen another property called "Enabling Parameter Name", this allows you to enable control of this element of the form with a Boolean (True/False) in your User Parameters, I typically just put an "F_" at the beginning the matching parameter name so I know this parameter is for Form control, then select the boolean parameter from the drop down list in the form edit.
What I typically do is write a different rule called "Form", and used Event Triggers to run the rule on every Model Parameter Change so when a parameter in the form is changed the rule runs and changes the boolean parameter to False to disable user entry.
If tfOUTLET_OD = False Then
     F_tfINLET_OD = False
ElseIf tfOUTLET_OD = True Then
     F_tfINLET_OD = True
End If
in reply to: philip1009
Thanks for your input, however its not the enabling/disabling of the parameter I am looking to change. I always want the parameter to be enabled.
Its the ability for the end user to enter a custom value that's not part of the multi-value list, based on the condition of a Boolean parameter.
I'm currently getting around it by having a separate parameter (i.e. CustomINLET_OD) and using the boolean to enable/disable this and the standard INLET_OD oppositely. But it'd be a lot cleaner if I could just access the Form properties as mentioned and have only one parameter.
philip1009
The only other solution to get a form that operates exactly the way you want it to is make it in Visual Studio Express (which is free), then under the Wizards tab in the iLogic code editor is a button called Create Rule for a Dialog.
Here's a playlist of tutorials on Visual Studio and Visual Basic itself:
https://www.youtube.com/watch?v=mM3zB3QWuv8&index=1&list=PLC601DEA22187BBF1
Here's a video showing how to use the Create Rule for a Dialog Wizard to add the VB Form to your iLogic rule:
https://www.youtube.com/watch?v=eS7Ua_xtbyE&t=3349s
Good luck.
