Hi All,
Looking at this new feature to Inventor 2018, I thought that it was a great addition! The only thing I am yet to figure out is how to get this feature to be active, it seems like it has it's own mind, sometimes it's there, sometimes it's not. As you could possibly guess from my post, right now it's not working.
I've tried looking through the Help sections but it seems to state that it is always on?
Am I missing something here? Like a button or keyboard shortcut?
Solved by bradeneuropeArthur. Go to Solution.
This idea has been implemented within Autodesk Inventor 2018.2. Autocomplete is enabled for; Inventor parameters, iLogic objects and functions, Inventor API objects & .NET objects. Special thanks to everyone who cast a vote for it.
do you have service pack 2???
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Found the issue.
One PC had 2018.2, whilst the other is on 2018.1. No wonder it wasn't appearing.
Thanks for pointing it out. Can't see the woods through the trees some days.
