Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to get part position
4 REPLIES 4
AnJanson
3119 Views, 4 Replies
I have a quiet simple question. How can I get the xyz position of a part/ComponentOccurrence in an assembly.
I did some tests and found the Transformation.Translation vector.
But the values for x, y and z are only one tenth of the real value (e.g. x is 2222, but the vector.x property gives me 222.2).
My assembly untis are in mm.
Regards Andreas
4 REPLIES 4
bshbsh
in reply to: AnJanson
inventor always uses centimeters internally. you need to convert it to the units you need (eg. the model units). it's simple in the case of cm-mm, but there are built-in unit conversion functions as well.
MechMachineMan
in reply to: bshbsh
Sample:
Sub Main()
On Error Goto Handler:
	Dim oDoc As AssemblyDocument
	oDoc = ThisApplication.ActiveDocument
	If oDoc Is Nothing Then
        Exit Sub
    End If
    'Ensure you are at the right point to select objects.
    Select Case True
        Case Not oDoc.ActivatedObject Is Nothing
            If oDoc.ActivatedObject.Type = ObjectTypeEnum.kDocumentObject Then
                oDoc = oDoc.ActivatedObject
            Else
                MsgBox ("Invalid active object")
                Exit Sub
            End If
        Case oDoc.ActivatedObject Is Nothing
            'Continue without revising anything
        Case Else
            MsgBox ("Invalid Activated Object!")
    End Select
On Error Goto 0
    Dim oSS As SelectSet
    oSS = oDoc.SelectSet
      If oSS.Count >= 1
		Call ProcessBulkLocations(oSS)
      End If
	Exit Sub
Handler:
	MsgBox("Doc Not an Assembly!")
End Sub
Sub ProcessBulkLocations(oSS As SelectSet)
    For Each oItem In oSS
        If oItem.Type = ObjectTypeEnum.kComponentOccurrenceObject Then
           	Call GetOccOrigin(oItem)
        End If
    Next
End Sub
Sub GetOccOrigin(oOcc As ComponentOccurrence)
	Dim oUOM As UnitsOfMeasure
	oUOM = ThisApplication.ActiveDocument.UnitsOfMeasure
	' Get the current transformation matrix from the occurrence.
   	Dim oTransform As Matrix
   	oTransform = oOcc.Transformation
	Dim oOriginLocation As Vector
	oOriginLocation = oTransform.Translation
	ptX = oUOM.ConvertUnits(oOriginLocation.X, "cm", "in")
	ptY = oUOM.ConvertUnits(oOriginLocation.Y, "cm", "in")
	ptZ = oUOM.ConvertUnits(oOriginLocation.Z, "cm", "in")
	MsgBox(ptX & vbLf & ptY & vbLf & ptZ)
   	' Move the occurrence honoring any existing constraints.
   	''oTransform.SetTranslation ThisApplication.TransientGeometry.CreateVector(2, 2, 3)
   	''oOccurrence.Transformation = oTransform
   	' Move the occurrence ignoring any constraints.
   	'Anything that causes the assembly to recompute will cause the
   	'occurrence to reposition itself to honor the constraints.
   	''oTransform.SetTranslation ThisApplication.TransientGeometry.CreateVector(3, 4, 5)
   	''Call oOccurrence.SetTransformWithoutConstraints(oTransform)
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
AnJanson
in reply to: MechMachineMan
Thank you Justin for the snippet and thank you János for the information, that Inventor always uses cm internally.
Regards Andreas
I think I have a similar request. I have this assembly with a form where the user can choose between having 1, 2 or 3 of the same part (but 3 different occurrences)
Those parts are constrained in 2 axis, but can move freely in the third axis. I'd like to be able to capture, or get, the current position of those parts somehow and put that one coordinate in a parameter that can be exported into a XML file.
So I made this dummy assembly that recreates exactly the problem that I have, just not the real thing. There's a form in there that should open with the document. In that form you have the option to load 1, 2 or 3 parts, and the ability to save the parameters to a XML .
But right now, I really don't know where to start to capture that position. And I'm a beginner in VB and iLogic so that code above really makes very little sense to me. My plan B would be to constrain those parts to some plane and have a slider change the offset, but at first, I'd like to see if there's a more elegant way of doing this. Also, I like that very intuitive way of just grabbing the part and positioning it manually (without having to rely on a slider), I'd like to retain that.
I guess I just need someone to either, explain that snippet above, or send me in some direction to help me start.
Technology Administrators
