Get data from the "Where used" tab in vault to add to the drawing title blocks using ilogic (automatically)
Hi all
I need to obtain data from the part - in vault there is a where used tab which shows the assemblies the part is used in.
I need to add that data array to a custom drawing title block for reference during manufacturing.
Doing this manually takes far too much time
JelteDeJong
you might wnat to have a look at this blog post:
https://adndevblog.typepad.com/manufacturing/2019/04/connecting-vault-and-accessing-vault-file-statu...
Jelte de Jong
Blog: hjalte.nl - github.com
bradeneuropeArthur
What if it is used multiple times?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
I have vault and parts will be used multiple times.
I believe that will give a few issues except whenever a part will be used in another assembly, it will always be copy designed and the file name renamed.
