Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
generate stock number from parameter values
3 REPLIES 3
Keith.Challinor3761
479 Views, 3 Replies
using iLogic I am trying to generate an automatic stock number based on existing parameters in a part
i have parameters of "code" (S) , "dia" (500) and "length" (1000) that change based the apart is used , i require a stock code based on those parameters that will look like S/500/1000
could anyone point me in the right direction please
TIA
Keith
3 REPLIES 3
iProperties.Value("Project", "Stock Number")= Code &"/"& Dia & "/" &Length
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Thanks Arthur
let me test and get back to you
appreciate the quick response
Keith
EXCELLENT THANK YOU
