Flat pattern in macro doesnt work
Hello
please I am looking for help.
I've got this macro below and everything works exept of flat pattern dimensions. Do you know where the problem is?
Thak You for your help.
 Vito
Sub Main ()
Dim oDoc As Inventor.Document
Dim oPartDoc As Inventor.PartDocument
Dim oCompDef As Inventor.ComponentDefinition
Dim oFlatExtent As Boolean = False
Try
oDoc = ThisDoc.Document
If oDoc.DocumentType = kPartDocumentObject Then
oPartDoc = oDoc
If oPartDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
oCompDef = oPartDoc.ComponentDefinition
If oCompDef.HasFlatPattern = True Then
oFlatExtent = True
If oFlatExtent = False Then
L = Round(Measure.ExtentsLength,1)
B = Round(Measure.ExtentsWidth, 1)
H = Round(Measure.ExtentsHeight, 1)
iProperties.Value("Custom", "Rozmer") = L & "x" & B & "x" & H
Else
L = Round(SheetMetal.FlatExtentsLength, 1)
B = Round(SheetMetal.FlatExtentsWidth, 1)
H = Parameter("Tloušťka")
iProperties.Value("Custom", "Rozmer") = H & "-" & L & "x" & B
iProperties.Value("Custom", "Délka rozvinu") = "" & L
iProperties.Value("Custom", "Šířka rozvinu") = "" & B
iProperties.Value("Custom", "Tloušťka plechu") = "" & H
Catch ex As Exception
iProperties.Value("Custom", "Rozmer") = "iLogicRule Error"
End Try
End Sub
Oh Im sorry I have already figured it out. The problem was in chzech language.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
It is nice to hear that you found a solution for question.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
bradeneuropeArthur
Could you please mark it as solved then, for administrative reasons.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
