Announcements
Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Inventor Api - Set focus back to inventor
connor.ferguson
connor.ferguson
I am writing an Inventor addin, i have a command that displays a windows from (non-modal). Then similar to Inventor normal ui i have a button the user can click to select an edge. This issue i have is when the user clicks this button, they then need to click inside Inventor for the selection to become active, then they can see the prompt and select the edge.
I have set inventors window as the form owner. Is there a way to get the focus back to inventor and not my form?
bradeneuropeArthur
form.hide
then'
form.show
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
