Change component iPart
06:36 AM
I've a routine made in VB6 which inserts and constains a iPart in a assembly. Now I want to call the Change Component command which shows the dialog to change a ipart component. See attached file.
I tried this with "AssemblyEditComponentCtxCmd"
But that don't work. What's the right commandname for this?
I use INV 2009
Dim oControlDef As ControlDefinition
oINVapp.ActiveDocument.SelectSet.Select oOcc1
Set oControlDef = oINVapp.CommandManager.ControlDefinitions.Item("AssemblyEditComponentCtxCmd")
oControlDef.Execute
I use INV 2009
oControlDef.Execute
