Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
External Rule runs abnormally
5 REPLIES 5
swalroth8KYHK
420 Views, 5 Replies
I wrote a quick External Rule that would truncate the first ten digits from the default file name in the Assembly Browser.
It seemed to work perfectly for a time, but now it's renaming all parts as they are entered (I only want it run in specific assemblies) and not even uniformly at that.
Each part file is a unique part with a unique name, but some of them are coming in as multiple instances with the same name, others are being renamed correctly. and its firing immediately without the msgBox appearing.
The code is below:
Sub Main()
Dim CNC as Integer
CNC = MsgBox("Drawing for CNC?", vbYesNo + vbQuestion, "For CNC")
If CNC = vbYes Then
Dim Path As String = ThisDoc.Path & "\"
InvDoc = ThisDoc.Document
Dim pCab As DocumentsEnumerator = InvDoc.AllReferencedDocuments
Dim sCab As Document
Dim oName As String
Dim nName As String
Dim nStart As Short
Dim nEnd As Short
For Each sCab In pCab
oName = sCab.DisplayName
nStart = 10
nEnd = Len(oName) - nStart
If nEnd >= 8
nName = oName.Substring(nStart,nEnd)
sCab.DisplayName = nName
End If
Next
Else
Exit Sub
End If
End Sub
Any help would be appreciated, thank you!
5 REPLIES 5
1. Display Name and Browser Node label are two very different things
2. If changing the Browser node label, you need to be concerned with the ":#" portion as you can't have a duplicate name.
3. Updating the display name does not necessarily update the browser name.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
1. I'm not sure which I need to change so it transfers correctly to Solid-CIM. Where and how are those two properties stored?
2. Each part has a unique name to begin with so there should never be multiple instances of a name.
3. So if Browser Node Label is the "correct" way to rename my parts, how do I do that in an iLogic Rule?
4. Is there a way to prevent my External Rules from seemingly running automatically?
A good starting point is probably finding this out.
There is a display name field in the part's iProperties. There is an occurrence name in the occurences 'iProperties'. You could do some testing to see what your next phase needs.
If you double click a name in the browser and name it something, then name the next node the same thing, you will get a "Name already in use" error.
It's not necessarily the correct name. It defends on your needs.
BrowserNodeDefinition and either label or some other property is what controls it. Should be easy enough to check with the object browser in VBA.
In the rule window, make sure the settings aren't selected for "run automatically". Also ensure the rule isn't connected to any event triggers.
Justin K
I am unable to find any code relating to changing a parts Browser Node Label, I keep getting errors saying its not for PartDocuments.
Also, I can't seem to get the box for Don't run automatically to stay checked. Is there something I need to add to the .txt file to set this?
A quick search of Autodesk's nicely provided online reference material...
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-70282D24-D08A-4EA4-9BEA-56B87826573F
Justin K
