Exporting .dwg with the PartNumber as it's name
hello, i have some code that exports all my drawings from an assembly in .dwg, with the part as there name but i need it to export with the part number. i've tried some variations but can't seem to figure it out.
Sub Main()
    Dim doc As AssemblyDocument = ThisDoc.Document
    For Each refDoc As Document In doc.AllReferencedDocuments
        Dim fileName As String = refDoc.FullFileName
        Dim ext As String = IO.Path.GetExtension(fileName)
        Dim inventorDwgFileName As String = fileName.Replace(ext, ".dwg")
        Dim autocadDwgFileName As String =(iProperties.Value("Project", "Part Number"), "-acad.dwg")
        If (IO.File.Exists(inventorDwgFileName) = False) Then
            MsgBox("Could not find inventor dwg: " & inventorDwgFileName)
            Continue For
        End If
        Dim dwgDoc As DrawingDocument = ThisApplication.Documents.Open(inventorDwgFileName)
        DWGOutUsingTranslatorAddIn(dwgDoc, autocadDwgFileName)
        dwgDoc.Close(True)
    Next
End Sub
Public Sub DWGOutUsingTranslatorAddIn(doc As DrawingDocument, newFileName As String)
    ' Set the path to your DWGOut.ini fiile here
    Dim dwgOutIniFile As String = "C:\Users\Monkey\Documents\Modularte\Cubo\DWGOut.ini"
    Dim oDWGAddIn As TranslatorAddIn = Nothing
    Dim i As Long
    For i = 1 To ThisApplication.ApplicationAddIns.Count
        If ThisApplication.ApplicationAddIns.Item(i).ClassIdString = "{C24E3AC2-122E-11D5-8E91-0010B541CD80}" Then
            oDWGAddIn = ThisApplication.ApplicationAddIns.Item(i)
            Exit For
        End If
    Next
    If oDWGAddIn Is Nothing Then
        MsgBox("DWG add-in not found.")
        Exit Sub
    End If
    If (IO.File.Exists(dwgOutIniFile) = False) Then
        MsgBox("Unable to find: " & dwgOutIniFile)
        Exit Sub
    End If
    If Not oDWGAddIn.Activated Then
        oDWGAddIn.Activate()
    End If
    Dim oNameValueMap As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap()
    oNameValueMap.Add("Export_Acad_IniFile", dwgOutIniFile)
    Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext()
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oOutputFile As DataMedium = ThisApplication.TransientObjects.CreateDataMedium()
    oOutputFile.FileName = newFileName
    Call oDWGAddIn.SaveCopyAs(doc, oContext, oNameValueMap, oOutputFile)
End Sub
bradeneuropeArthur
Change this:
Sub Main()
        Dim autocadDwgFileName As String =iProperties.Value("Project", "Part Number")& "-acad.dwg"
            Continue For
        End If
        dwgDoc.Close(True)
    Next
End Sub
    Dim i As Long
            Exit For
        End If
    Next
        Exit Sub
    End If
        Exit Sub
    End If
    End If
End Sub
Arthur Knoors
Autodesk Affiliations:
