Export Excel file with iLogic
byzkc54
Message 1 of 10
byzkc54
I want the product codes of the products included in the assembly to be sorted in excel according to the material properties. At the same time, it would be perfect if it also shows how many quantity were used in the assembly. For example, the photo below.
Replies (9)
Message 2 of 10
bradeneuropeArthur
Is Export the Bill Of Material not what you need here?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 10
byzkc54
yes, I forgot, I'm sorry. I just wanted to export materials that are sheet metal.
Message 4 of 10
bradeneuropeArthur
In principle you need an filtered (sheetmetal) export of the bill of material, correct?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 10
byzkc54
yes, only sheet metal
Message 6 of 10
Andrii_Humeniuk
Hi @byzkc54 . I hope this is exactly what you wanted. Please check if everything works.
Sub main
	Dim oDoc As Document = ThisApplication.ActiveDocument
	Dim oUOM As UnitsOfMeasure = ThisApplication.UnitsOfMeasure
	If TypeOf oDoc Is AssemblyDocument Then
		Dim oADoc As AssemblyDocument = oDoc
		Dim sPath As String = System.IO.Path.GetDirectoryName(oADoc.FullFileName)
		Dim sName As String = "Sheet Metal List"
		Dim sFullNameExcel As String = sPath & "\" & sName & ".xlsx"
		Dim sListMaterial As New List(Of String)
		sListMaterial.AddRange(GetMaterialFromAssembly(oADoc.AllReferencedDocuments, oUOM))
		If sListMaterial.Count <> 0 Then
			sListMaterial.Sort()
			Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
			Dim oBOMView As BOMView = GetBOM_OnlyParts(oADef.BOM)
			If oBOMView Is Nothing Then Exit Sub
			Dim sNameAndQty As New List(Of String)
			oExcel = CreateObject("Excel.Application")
			If Not System.IO.File.Exists(sFullNameExcel) Then
				oExcel.Visible = False
				excelWorkbook = oExcel.Workbooks.Add
				ExcelSheet = excelWorkbook.Worksheets(1)
				ExcelSheet.Name = "Sheet1"
				excelWorkbook.SaveAs(sFullNameExcel)
				excelWorkbook.Close
				oExcel.Quit
			excelWorkbook = oExcel.Workbooks.Open(sFullNameExcel)
			oSheet = excelWorkbook.Worksheets(1)
			oSheet.Cells.ClearContents
			For iMater As Integer = 1 To sListMaterial.Count Step 1
				oSheet.Cells(1, iMater).Value = sListMaterial.Item(iMater - 1)
				sNameAndQty.AddRange(GetFullNameAndQty(oBOMView.BOMRows, sListMaterial.Item(iMater-1), oUOM))
				sNameAndQty.Sort()
				If sNameAndQty.Count <> 0 Then
					For iName As Integer = 1 To sNameAndQty.Count Step 1
						oSheet.Cells(iName+1, iMater).Value = sNameAndQty.Item(iName-1)
					Next iName
				sNameAndQty.Clear()
			Next iMater
			oSheet.Columns.AutoFit()
			excelWorkbook.Save()
			excelWorkbook.Close()
	Else
		MessageBox.Show("Active document is not AssemblyDocument", "Error!",MessageBoxButtons.OK,MessageBoxIcon.Error)
End Sub
Private Function GetBOM_OnlyParts(oBOM As BOM) As BOMView
	Dim sLanguageBOM As String
	If Not oBOM.PartsOnlyViewEnabled Then oBOM.PartsOnlyViewEnabled = True
	Select Case ThisApplication.LanguageCode
	Case "en-US"
		sLanguageBOM = "Parts Only"
	End Select
	Return oBOM.BOMViews.Item(sLanguageBOM)
End Function
Private Function GetFullNameAndQty(ByVal oBOMRows As BOMRowsEnumerator, ByVal sMatName As String, ByVal oUOM As UnitsOfMeasure) As List(Of String)
	For Each oRow As BOMRow In oBOMRows
		If TypeOf oRow.ComponentDefinitions.Item(1) Is SheetMetalComponentDefinition Then
			Dim oSheetDef As SheetMetalComponentDefinition = oRow.ComponentDefinitions.Item(1)
			Dim oPartDoc As PartDocument = oSheetDef.Document
			Dim sPartNumb As String = oPartDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
			Dim sMaterial As String = oPartDoc.ActiveMaterial.DisplayName
			Dim dThick As Double = oUOM.ConvertUnits(oSheetDef.Thickness.Value, "cm", "mm")
			If sMaterial & " " & dThick & "mm" = sMatName Then
				sNameAndQty.Add("6-01" & sPartNumb & "_" & oRow.ItemQuantity & "Qty")
	Next
	Return sNameAndQty
End Function
Private Function GetMaterialFromAssembly(ByVal oRefDocs As DocumentsEnumerator, ByVal oUOM As UnitsOfMeasure) As List(Of String)
	Dim sListMaterial, sListFinal As New List(Of String)
	For Each oRefDoc As Document In oRefDocs
		If TypeOf oRefDoc Is PartDocument Then
			Dim oPartDoc As PartDocument = oRefDoc
			If TypeOf oPartDoc.ComponentDefinition Is SheetMetalComponentDefinition Then
				Dim oSheetDef As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
				If Not sListMaterial.Contains(sMaterial & " " & dThick & "mm") Then
					sListMaterial.Add(sMaterial & " " & dThick & "mm")
	Next
	Return sListMaterial
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 7 of 10
byzkc54
Thank you Mr Andrii.
Your code is working perfectly. But i just have one more question. I wonder if you can make it work when there is a suppress part in the assembly?
Because when I have a suppress part in my assembly, your code does not run.
Message 8 of 10
Andrii_Humeniuk
No problem, try this code:
Sub main
				excelWorkbook.Close
				oExcel.Quit
				sNameAndQty.Sort()
					Next iName
				sNameAndQty.Clear()
			Next iMater
	Else
End Sub
	Case "en-US"
	End Select
End Function
		If oRow.ItemQuantity <> 0 Then
		End if
	Next
	Return sNameAndQty
End Function
	Next
End Function
Message 9 of 10
byzkc54
Message 10 of 10
Andrii_Humeniuk
It looks like you are using an older version of 2022 Inventor. I hope the new changes will help you.
Sub main
		sListMaterial.AddRange(GetMaterialFromAssembly(oBOMView.BOMRows, oUOM))
				excelWorkbook.Close
				oExcel.Quit
				sNameAndQty.Sort()
					Next iName
				sNameAndQty.Clear()
			Next iMater
	Else
End Sub
	Case "en-US"
	End Select
End Function
		End if
	Next
	Return sNameAndQty
End Function
Private Function GetMaterialFromAssembly(ByVal oBOMRows As BOMRowsEnumerator, ByVal oUOM As UnitsOfMeasure) As List(Of String)
	Next
End Function
