Export STEP file from member of ipart and assign specific name to it
cgoethalsFU8PY
cgoethalsFU8PY
Dear Autodesk members.
I am trying to adapt my code to bulk export .STEP files from .iam documents and while doing this assign them the following name: Subject - Filename of .iam
When I use the following code my .iam-files are exported to .STEP-files, but the right name is not assigned as I want. Would it be possible to help me out?
Thank you very much on forehand!
Sub main()
    Dim oSTEPTranslator As TranslatorAddIn
    Dim oContext As TranslationContext
    Dim oOptions As NameValueMap
    Dim oDataMedium As DataMedium
    Call ConfigureoSTEPTranslatorSettings(oSTEPTranslator, oContext, oOptions, oDataMedium)
    Dim oFileDlg As Inventor.FileDialog = Nothing
    InventorVb.Application.CreateFileDialog(oFileDlg)
    'oFileDlg.Filter = "Inventor Files (*.iam)|*.iam"
    oFileDlg.DialogTitle = "Delete Ilogic Rule in drawing"
    oFileDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.FullFileName ' ThisDoc.Path
    oFileDlg.MultiSelectEnabled = True
    'oFileDlg.FilterIndex = 1
    oFileDlg.CancelError = True
    On Error Resume Next
    oFileDlg.ShowOpen()
    If Err.Number <> 0 Then
        MessageBox.Show("File not chosen.", "Dialog Cancellation")
    ElseIf oFileDlg.FileName <> "" Then
        For Each wrd In oFileDlg.FileName.Split("|") 'Words
            Dim odoc As Document = ThisApplication.Documents.Open(wrd, True)
            oOptions.Value("FileName") = odoc.iProperties.Value("Summary", "Subject") & " - " & odoc.FileName(False)
            oDataMedium.FileName = Left(odoc.FullFileName, (InStrRev(odoc.FullFileName, ".", -1, vbTextCompare) - 1)) & ".stp"
            Call oSTEPTranslator.SaveCopyAs(odoc, oContext, oOptions, oDataMedium)
            odoc.Close
        Next
    MessageBox.Show("STEP-Export geslaagd. Proficiat! Je hebt zonet heel wat tijd uitgespaard! Groetjes, jullie programmeergenie Cor :)")
End Sub
Sub ConfigureoSTEPTranslatorSettings(ByRef oSTEPTranslator As TranslatorAddIn, ByRef oContext As TranslationContext, ByRef oOptions As NameValueMap, ByRef oDataMedium As DataMedium)
    oPath = ThisDoc.Path
    oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
    oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
    oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
End Sub
WCrihfield
Hi @cgoethalsFU8PY.  You can give this slightly edited version a try.
Sub main()
    oFileDlg.ShowOpen()
			Dim oPath As String = System.IO.Path.GetDirectoryName(odoc.FullFileName)
            Dim sSubject As String = odoc.PropertySets.Item(1).Item("Subject").Value
			Dim sFileNameWOExt As String = System.IO.Path.GetFileNameWithoutExtension(odoc.FullFileName)
            oDataMedium.FileName = oPath & "\" & sSubject & " - " & sFileNameWOExt & ".stp"
            odoc.Close
        Next
End Sub
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
cgoethalsFU8PY
Thank you very much!
cgoethalsFU8PY
@WCrihfield
I'm having the same issue with my pdf exporter since I need to refer to the subject of one of my drawing views. How do you suggest tackling this? Hereby you can find my code.
Sub main()
Dim PDFAddIn As TranslatorAddIn
Call ConfigurePDFAddinSettings(PDFAddIn, oContext, oOptions, oDataMedium)
oFileDlg.Filter = "Inventor Files (*.idw)|*.idw"
oFileDlg.MultiSelectEnabled =True
oFileDlg.ShowOpen()
		Dim oView As DrawingView
		Dim sSubject As String = oView.ReferencedDocumentDescriptor.ReferencedDocument.iProperties.Value(oViewModelName, "Subject")
        oDataMedium.FileName = oPath & "\" & oPartname & " - " & sFileNameWOExt & ".pdf"
		Call PDFAddIn.SaveCopyAs(odoc, oContext, oOptions, oDataMedium)
		odoc.Close
	Next
MessageBox.Show("PDF-Export geslaagd. Proficiat! Je hebt zonet heel wat tijd uitgespaard!")
End Sub
Sub ConfigurePDFAddinSettings(ByRef PDFAddIn As TranslatorAddIn, ByRef oContext As TranslationContext, ByRef oOptions As NameValueMap, ByRef oDataMedium As DataMedium)
	PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oOptions.Value("All_Color_AS_Black") = 0
	oOptions.Value("Remove_Line_Weights") = 1
	oOptions.Value("Vector_Resolution") = 400
	'oOptions.Value("Custom_Begin_Sheet") = 1
	'oOptions.Value("Custom_End_Sheet") = 1
End Sub
WCrihfield
Hi @cgoethalsFU8PY.  I am not sure if this will work for you or now without asking several related questions, but here is an attempt to fix your PDF export iLogic rule code.  I left a few comments in there that may help you, if it does not work right away.
Sub Main
	ThisApplication.CreateFileDialog(oFileDlg)
	Try
		oFileDlg.ShowOpen
	Catch
		Exit Sub
	End Try
	Dim sSelection As String = oFileDlg.FileName
	If sSelection = "" Then Exit Sub
	Dim oFiles As New List(Of String)
	If sSelection.Contains("|") = False Then
		oFiles.Add(sSelection)
	ElseIf sSelection.Contains("|") = True Then
		oFiles.AddRange(sSelection.Split("|"))
	For Each sFile In oFiles
		'since the file filter is for drawing files only, I assume every file will be a drawing file
		Dim oDDoc As DrawingDocument = ThisApplication.Documents.Open(sFile, False)
		Dim oPath As String = System.IO.Path.GetDirectoryName(oDDoc.FullFileName)
		'and here I assume there will always be a DrawingView on the first sheet of the drawing file, representing the model we need to access
		Dim oView As DrawingView = oDDoc.Sheets.Item(1).DrawingViews.Item(1)
		'the model file being referenced within that view should already be loaded into Inventor's memory by opening the drawing
		Dim oViewDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument
		Dim sSubject As String = oViewDoc.PropertySets.Item(1).Item("Subject").Value
		Dim sFileNameWOExt As String = System.IO.Path.GetFileNameWithoutExtension(oDDoc.FullFileName)
		oDataMedium.FileName = oPath & "\" & sSubject & " - " & sFileNameWOExt & ".pdf"
		Call PDFAddIn.SaveCopyAs(oDDoc, oContext, oOptions, oDataMedium)
		oDDoc.Close
	Next
	ThisApplication.Documents.CloseAll(True) 'True  = closes unreferenced documents only
End Sub
End Sub
Wesley Crihfield
cgoethalsFU8PY
@WCrihfield thank you. It is clear for me now that not all heroes wear capes!
