is there any possibility to exit (break) before save event trigger?
For example. We have several iRules which are run Before Save (event trigger). First one is checking if correct "Project File" is selected, if it is, continue executing other Before Save iRules, but if it is not correct one, exit (break) the Before Save Event Trigger to prevent executing further iRules on Before Save (causing errors obviously).
Best regards,
Rene Repina
Solved by j.haggenjos. Go to Solution.
Solved by bradeneuropeArthur. Go to Solution.
With the build in application events of ilogic this is not possible to skip I am afraid.
With the use of an addin this is possible to do in some kind of way. For example on command start event.
Arthur Knoors
Autodesk Affiliations:
There is a way to make it work. I used a similar technique before moving to an AddIn to have more control.
In your base rule, you create a Shared Variable, and in the other rules, based on the value in the shared variable, you can decide to run or not. The rule are always run, but you can just decide to skip them.
Main rule:
If ProjectFile is Correct Then
SharedVariable("ShouldTriggerRun") = True
Else
SharedVariable("ShouldTriggerRun") = False
End If
And in your other rules:
If SharedVariable.Exists("ShouldTriggerRun") AndAlso Not SharedVariable("ShouldTriggerRun") Then Exit Sub
Ah, too bad. Addin could work, but we are trying to do without them. Thanks anyway!
Thank you for the answer!
This could work yes, with NameValueMap or something similiar, but we have a lot of rules and we would have to include this in all of them.
Currently we have one main iRule which is in Event Triggers and this iRule is calling others. We have similiar concept as you described. Because we have only 1 iRule in Event Triggers, we exit that one if something goes wrong, but it is not optimal, since in some cases, it should exist in some middle iRule.
Thanks for answers and new options!
For fine control of event, I would go the AddIn route as suggested by @bradeneuropeArthur .
However, in both AddIn and iLogic rule, using boolean flags to decide on how to process the event will be my suggestion. You can turn on the flag anywhere in your code and then later, depending if a flag is on or not, react accordingly.
In your example of exiting in the middle of a rule:
At some point in one rule:
If condition is met Then SharedVariable("StopInMiddle") = True
And in the other rule:
Do something
If SharedVariable.Exists("StopInMiddle") Then
SharedVariable.Remove("StopInMiddle")
Exit Sub
End If
Do some more thing only if flag is off
The good thing with SharedVariable is that you can access them from any rules at any time. You don't have to pass argument around between rules. Similarly as how you would use global variables in an AddIn.
In my example here, I consider the flag to be used only for one thing. So the variable existence is enough to decide and I can remove the flag before going further. It doesn't need to be implemented in all the rules. Only the rule where you "decide" that you want to stop the other rule in the middle, and in the rule that you actually need to exit early. All the other rules will just ignore the shared variable.
