Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Errors when building Inventor 2019 Addin with Visual Studio 2019 and Nifty Addin template
9 REPLIES 9
Message 1 of 10
JBerns
1369 Views, 9 Replies
Community,
On a new workstation I have installed Windows 10 Pro, Inventor 2019, Visual Studio 2019, and .NET 4.8.
When I try to build an addin using @BrianEkins 'Nifty Add-in Inventor 2018' template, a couple of errors are reported, but VS reports a successful build. Please see below:
1>------ Build started: Project: Inventor_Addin_2020-11-05_A, Configuration: Debug Any CPU ------
1>  Inventor_Addin_2020-11-05_A -> C:\Users\jberns\source\repos\Inventor_Addin_2020-11-05_A\bin\Debug\Inventor_Addin_2020-11-05_A.dll
1>  '"\VsDevCmd"' is not recognized as an internal or external command, operable program or batch file.
1>  'mt.exe' is not recognized as an internal or external command, operable program or batch file.
1>  C:\Users\jberns\source\repos\Inventor_Addin_2020-11-05_A\Autodesk.Inventor_Addin_2020-11-05_A.Inventor.addin
1>  1 File(s) copied
1>  C:\Users\jberns\source\repos\Inventor_Addin_2020-11-05_A\ButtonResources\SampleButton\16x16.png -> C:\Users\jberns\source\repos\Inventor_Addin_2020-11-05_A\bin\Debug\ButtonResources\SampleButton\16x16.png
1>  C:\Users\jberns\source\repos\Inventor_Addin_2020-11-05_A\ButtonResources\SampleButton\32x32.png -> C:\Users\jberns\source\repos\Inventor_Addin_2020-11-05_A\bin\Debug\ButtonResources\SampleButton\32x32.png
1>  2 File(s) copied
1>  The system cannot find the path specified.
1>  C:\Users\jberns\source\repos\Inventor_Addin_2020-11-05_A\bin\Debug\Autodesk.Inventor_Addin_2020-11-05_A.Inventor.addin -> C:\Users\jberns\AppData\Roaming\Autodesk\ApplicationPlugins\Inventor_Addin_2020-11-05_A\Autodesk.Inventor_Addin_2020-11-05_A.Inventor.addin
1>  C:\Users\jberns\source\repos\Inventor_Addin_2020-11-05_A\bin\Debug\Inventor_Addin_2020-11-05_A.dll -> C:\Users\jberns\AppData\Roaming\Autodesk\ApplicationPlugins\Inventor_Addin_2020-11-05_A\Inventor_Addin_2020-11-05_A.dll
1>  C:\Users\jberns\source\repos\Inventor_Addin_2020-11-05_A\bin\Debug\Inventor_Addin_2020-11-05_A.xml -> C:\Users\jberns\AppData\Roaming\Autodesk\ApplicationPlugins\Inventor_Addin_2020-11-05_A\Inventor_Addin_2020-11-05_A.xml
1>  C:\Users\jberns\source\repos\Inventor_Addin_2020-11-05_A\bin\Debug\ButtonResources\SampleButton\16x16.png -> C:\Users\jberns\AppData\Roaming\Autodesk\ApplicationPlugins\Inventor_Addin_2020-11-05_A\ButtonResources\SampleButton\16x16.png
1>  C:\Users\jberns\source\repos\Inventor_Addin_2020-11-05_A\bin\Debug\ButtonResources\SampleButton\32x32.png -> C:\Users\jberns\AppData\Roaming\Autodesk\ApplicationPlugins\Inventor_Addin_2020-11-05_A\ButtonResources\SampleButton\32x32.png
1>  5 File(s) copied
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
When I start Inventor, Addin Manager, the addin reports:
There was an error opening the file.
I have run the VsDevCmd.bat file to initialize the system. I have used the '-test' option, to which no errors are reported.
The only 'mt.exe' file on my system is found here:
C:\Program Files (x86)\Windows Kits\10\bin\10.0.18362.0\arm64\mt.exe
C:\Program Files (x86)\Windows Kits\10\bin\10.0.18362.0\x64\mt.exe
C:\Program Files (x86)\Windows Kits\10\bin\10.0.18362.0\x86\mt.exe
I discovered that a User Environment Variable and a System Environment Variable had not been set for VS2019. I added these.
Any thoughts as to what has not been installed or configured to cause the error for the Inventor addin?
Thank you for your time and attention. I look forward to your replies.
Jerry
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Labels (3)
9 REPLIES 9
Message 2 of 10
nils.korte
in reply to: JBerns
Hi JBerns,
unfortunately I have exactly the same problem and since your post is already a year old, I wanted to ask if you might have found a solution to it after all.
With kind regards.
Message 3 of 10
JBerns
in reply to: JBerns
@nils.korte,
I followed a #KETIV #AVA video ( https://www.youtube.com/watch?v=QROrJdg0NQ8 ) to build an Addin.
This time I used .NET 4.7 as shown in the video. Perhaps that was the problem I had earlier because I used 4.8
The video creates a new part. That part was successful. No errors. Addin works.
I tried to expand the Addin by using a form to ask the dimensions of a box for the new part, but have been unsuccessful.
For what its worth, I have attached the project in case someone wants to see where I have gone wrong. I compressed the VS solution folder and attached.
The (first) error occurs in the StandardAddInServer.vb file, subroutine m_sampleButton_OnExecute.
I try to set textbox values for the box position and dimensions, but I get an error:
     System.NullReferenceException: 'Object reference not set to an instance of an object.'
I am confident I have not allowed the class and the form to communicate correctly.
I am focusing on DLL interfaces for now, but hope to find a solution to addin errors.
Jerry
CAD Administrator
Using Inventor 2022
Message 4 of 10
bradeneuropeArthur
in reply to: JBerns
Does the msgbox rise?
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Message 5 of 10
JBerns
in reply to: JBerns
@bradeneuropeArthur,
Yes, the message does appear.
After the message box is closed, I then attempt to populate the form with values before showing it.
That is when the error occurs.
I can 'Continue' past the error and the form does appear, but without any values that I attempted to preset.
I suspect my lack of knowledge on making the class and the form communicate with each other is the problem.
Jerry
CAD Administrator
Using Inventor 2022
Message 6 of 10
nils.korte
in reply to: JBerns
thank you for the answer. I was able to solve the problems with the \VsDevCmd.bat and the mt.exe.
I changed the second line of the builder events to: call "%VSAPPIDDIR%..\Tools\vsdevcmd"
I also reinstalled the mt.exe via Windows SDK for Windows Store Apps Tools-x86_en-us.msi
I also deleted the last but one paragraph of the builder events, because it tried to delete a folder that does not exist.
Visual Studios does not show me any errors after building, but unfortunately Inventor still cannot launch the add-in.
Inventor permanently shows "There was an error opening the file".
I tried to load the add-in manually into Inventor, i.e. without the builder events. Unfortunately, that didn't work either.
It seems to me that there is another error in the template.
Message 7 of 10
JBerns
in reply to: nils.korte
@nils.korte,
Are you using Brian Ekins' Nifty Add-in Template? Especially, the update he posted:
https://ekinssolutions.com/nifty_addin_template/
Jerry
CAD Administrator
Using Inventor 2022
Message 8 of 10
nils.korte
in reply to: JBerns
Yes, I've downloaded it from that post.
Message 9 of 10
JBerns
Update:
I discovered the Build Events instructions contained a reference to VS2017.
     REM - Set up the environment.
     call "%VS150COMNTOOLS%\VsDevCmd"
I corrected to use VS2019 system variables
     call "%VS160COMNTOOLS%\VsDevCmd"
No more errors related to VsDevCmd or Mt.
Jerry
CAD Administrator
Using Inventor 2022
Message 10 of 10
alain_miltenburg
in reply to: JBerns
The following line will make calling VsDevCmd.bat Visual Studio version independant:
for /f "usebackq delims=#" %%a in (`"%programfiles(x86)%\Microsoft Visual Studio\Installer\vswhere" -latest -property installationPath`) do call "%%a\Common7\Tools\VsDevCmd.bat"
When testing this on a command line, you should replace both instances of %%a with %a.
