I am new to ilogic.
trying to read a value out of an excel workbook that is embedded in my IPT file.
I keep getting
hk_row = 9' deleted parameter 'width_row = 3' deleted parameter If thk >= 20 Then thk_row = "13" ElseIf thk >= 17 Then thk_row = "13" ElseIf thk >= 16 Then thk_row = "13" ElseIf thk >= 15 Then thk_row = "13" ElseIf thk >= 14 Then thk_row = "12" ElseIf thk >= 13 Then thk_row = "12" ElseIf thk >= 12 Then thk_row = "12" ElseIf thk >= 10 Then thk_row = "11" ElseIf thk >= 9 Then thk_row = "10" ElseIf thk >= 8 Then thk_row = "9" ElseIf thk >= 7 Then thk_row = "8" ElseIf thk >= 6 Then thk_row = "7" ElseIf thk >= 5 Then thk_row = "6" ElseIf thk >= 4 Then thk_row = "5" ElseIf thk >= 3 Then thk_row = "4" ElseIf thk >= 2 Then width_row = "3" ElseIf thk >= 1 Then thk_row = "2" ElseIf thk > 0 Then thk_row = "1" End If 'thk_column = 1' deleted parameter 'width_column = 8' deleted parameter If width >= 20 Then thk_column = "N" ElseIf width >= 17 Then thk_column = "N" ElseIf width >= 16 Then thk_column = "N" ElseIf width >= 15 Then thk_column = "N" ElseIf width >= 12 Then thk_column = "M" ElseIf width >= 10 Then thk_column = "L" ElseIf width >= 9 Then thk_column = "K" ElseIf width >= 8 Then thk_column = "J" ElseIf width >= 7 Then thk_column = "I" ElseIf width >= 6 Then thk_column = "H" ElseIf width >= 5 Then thk_column = "G" ElseIf width >= 4 Then thk_column = "F" ElseIf width >= 3 Then thk_column = "E" ElseIf width >= 2 Then thk_column = "D" ElseIf width >= 1 Then thk_column = "C" ElseIf width > 0 Then thk_column = "B" End If If lg >= 20 Then thk_chart = "Sheet39" ElseIf lg >= 17 Then thk_chart = "Sheet39" ElseIf lg >= 16 Then thk_chart = "Sheet39" ElseIf lg >= 15 Then thk_chart = "Sheet39" ElseIf lg >= 14 Then thk_chart = "Sheet25" ElseIf lg >= 12 Then thk_chart = "Sheet25" ElseIf lg >= 10 Then thk_chart = "Sheet24" ElseIf lg >= 9 Then thk_chart = "Sheet23" ElseIf lg >= 8 Then thk_chart = "Sheet22" ElseIf lg >= 7 Then thk_chart = "Sheet21" ElseIf lg >= 6 Then thk_chart = "Sheet20" ElseIf lg >= 5 Then thk_chart = "Sheet19" ElseIf lg >= 4 Then thk_chart = "Sheet18" ElseIf lg >= 3 Then thk_chart = "Sheet17" ElseIf lg >= 2 Then thk_chart = "Sheet16" ElseIf lg >= 1 Then thk_chart = "Sheet15" ElseIf lg > 0 Then thk_chart = "Sheet14" End If oPath = "\\filesrv\USERS\ENGINEERING\Inventor\" '("\\filesrv\Engineering\Inventor\Inventor\INVENTOR_MASTERS\rect_stk_chart.xlsx", "Sheet1", "help", "=", 1) oFileName = "thk_stk_rect.xlsx" colm = Parameter("thk_column") oPN = Parameter("thk_row") sht = Parameter("thk_chart") 'get row using part number oRow = GoExcel.FindRow(oPath & oFileName, sht,"ht", "=", oPN) Parameter("stk_thk") = GoExcel.CellValue("3rd Party:thk_stk_rect.xlsx", sht, colm & oPN ) 'get value in 2nd column 'Parameter("ID") = GoExcel.CellValue(oPath & oFileName, "Sheet1", "C" & oRow) 'get value in 3rd column 'Parameter("LG") = GoExcel.CellValue(oPath & oFileName, "Sheet1", "D" & oRow ) 'get value in 4th column InventorVb.DocumentUpdate()
errors that a cannot figure out.
Error in rule: look_thk_combine, in document: rect_new.ipt
GoExcel: Could not match the column title: "ht"
System.ArgumentException: GoExcel: Could not match the column title: "ht"
at iLogic.GoExcel.FindColumn(String columnName)
at iLogic.GoExcel.FindRow(String fileName, String sheetName, Object[] sizeArgs)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Solved by A.Acheson. Go to Solution.
Hi @vistametals
These can be difficult to figure out without the running file and excel sheet. I would suggest to step through the code moving the message box between each line with a message box and keep going untill it errors out. You can then be sure the preceeding line caused the error. You will also need to deal with the parameters that have been deleted.
You can also try and target the lines thst the error message identifies. Check why it cannot find the objects.
Another thing to note is all cells in a range need to be filled in. Do not leave them blank. Use N/A or similar.
Thank you. I deleted the unused parameters and filled in the blank ranges. Then the rule worked. Thanks again.
Great to here you got it working. Can you mark as solved what instructions worked for you so others can know it was successfull.
Great to hear you got it working. Can you mark as solved what instructions worked for you so others can know it was successfull.
