error in code
4 REPLIES 4
vistametals
279 Views, 4 Replies
error in code
I am new to ilogic.
trying to read a value out of an excel workbook that is embedded in my IPT file.
I keep getting
hk_row = 9' deleted parameter
'width_row = 3' deleted parameter
If thk >= 20 Then
	thk_row = "13"
ElseIf thk >= 17 Then
		thk_row = "13"
ElseIf thk >= 16 Then
		thk_row = "13"
ElseIf thk >= 15 Then
		thk_row = "13"
ElseIf thk >= 14 Then
		thk_row = "12"
ElseIf thk >= 13 Then
		thk_row = "12"
ElseIf thk >= 12 Then
		thk_row = "12"
ElseIf thk >= 10 Then
		thk_row = "11"
ElseIf thk >= 9 Then
		thk_row = "10"
ElseIf thk >= 8 Then
		thk_row = "9"
ElseIf thk >= 7 Then
		thk_row = "8"
ElseIf thk >= 6 Then
		thk_row = "7"
ElseIf thk >= 5 Then
		thk_row = "6"
ElseIf thk >= 4 Then
		thk_row = "5"
ElseIf thk >= 3 Then
		thk_row = "4"
ElseIf thk >= 2 Then
		width_row = "3"
ElseIf thk >= 1 Then
		thk_row = "2"
ElseIf thk > 0 Then
		thk_row = "1"
End If
'thk_column = 1' deleted parameter
'width_column = 8' deleted parameter
If width >= 20 Then
	thk_column = "N"
ElseIf width >= 17 Then
		thk_column = "N"
ElseIf width >= 16 Then
		thk_column = "N"
ElseIf width >= 15 Then
		thk_column = "N"
ElseIf width >= 12 Then
		thk_column = "M"
ElseIf width >= 10 Then
		thk_column = "L"
ElseIf width >= 9 Then
		thk_column = "K"
ElseIf width >= 8 Then
		thk_column = "J"
ElseIf width >= 7 Then
		thk_column = "I"
ElseIf width >= 6 Then
		thk_column = "H"
ElseIf width >= 5 Then
		thk_column = "G"
ElseIf width >= 4 Then
		thk_column = "F"
ElseIf width >= 3 Then
		thk_column = "E"
ElseIf width >= 2 Then
	    thk_column = "D"
ElseIf width >= 1 Then
		thk_column = "C"
ElseIf width > 0 Then
		thk_column = "B"
End If
If lg >= 20 Then
	thk_chart = "Sheet39"
ElseIf lg >= 17 Then
ElseIf lg >= 16 Then
ElseIf lg >= 15 Then
ElseIf lg >= 14 Then
		thk_chart = "Sheet25"
ElseIf lg >= 12 Then
ElseIf lg >= 10 Then
		thk_chart = "Sheet24"
ElseIf lg >= 9 Then
		thk_chart = "Sheet23"
ElseIf lg >= 8 Then
		thk_chart = "Sheet22"
ElseIf lg >= 7 Then
		thk_chart = "Sheet21"
ElseIf lg >= 6 Then
		thk_chart = "Sheet20"
ElseIf lg >= 5 Then
		thk_chart = "Sheet19"
ElseIf lg >= 4 Then
		thk_chart = "Sheet18"
ElseIf lg >= 3 Then
		thk_chart = "Sheet17"
ElseIf lg >= 2 Then
		thk_chart = "Sheet16"
ElseIf lg >= 1 Then
		thk_chart = "Sheet15"
ElseIf lg > 0 Then
		thk_chart = "Sheet14"
End If
oPath = "\\filesrv\USERS\ENGINEERING\Inventor\"
'("\\filesrv\Engineering\Inventor\Inventor\INVENTOR_MASTERS\rect_stk_chart.xlsx", "Sheet1", "help", "=", 1)
oFileName = "thk_stk_rect.xlsx"
colm = Parameter("thk_column")
oPN = Parameter("thk_row")
sht = Parameter("thk_chart")
'get row using part number
oRow = GoExcel.FindRow(oPath & oFileName, sht,"ht", "=", oPN)
Parameter("stk_thk") = GoExcel.CellValue("3rd Party:thk_stk_rect.xlsx", sht,  colm & oPN ) 'get value in 2nd column
'Parameter("ID") = GoExcel.CellValue(oPath & oFileName, "Sheet1", "C" & oRow) 'get value in 3rd column
'Parameter("LG") = GoExcel.CellValue(oPath & oFileName, "Sheet1", "D" & oRow ) 'get value in 4th column
InventorVb.DocumentUpdate()
errors that a cannot figure out.
Error in rule: look_thk_combine, in document: rect_new.ipt
GoExcel: Could not match the column title: "ht"
System.ArgumentException: GoExcel: Could not match the column title: "ht"
at iLogic.GoExcel.FindColumn(String columnName)
at iLogic.GoExcel.FindRow(String fileName, String sheetName, Object[] sizeArgs)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
4 REPLIES 4
A.Acheson
in reply to: vistametals
Hi @vistametals
These can be difficult to figure out without the running file and excel sheet. I would suggest to step through the code moving the message box between each line with a message box and keep going untill it errors out. You can then be sure the preceeding line caused the error. You will also need to deal with the parameters that have been deleted.
You can also try and target the lines thst the error message identifies. Check why it cannot find the objects.
Another thing to note is all cells in a range need to be filled in. Do not leave them blank. Use N/A or similar.
Regards
Alan
vistametals
in reply to: A.Acheson
Thank you. I deleted the unused parameters and filled in the blank ranges. Then the rule worked. Thanks again.
A.Acheson
Great to here you got it working. Can you mark as solved what instructions worked for you so others can know it was successfull.
Regards
Alan
A.Acheson
Great to hear you got it working. Can you mark as solved what instructions worked for you so others can know it was successfull.
Regards
Alan
