Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
how to give the good Parts name
6 REPLIES 6
hugo7
278 Views, 6 Replies
Hi i want that my rules generate the name off the parts automatically
heres my post my problem is at line 30
6 REPLIES 6
FINET_Laurent
in reply to: hugo7
Hello @hugo7,
How would the name be formated ? We can have any name you can think of.
Also, please copy paste the code here so we can implement it for you.
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
hugo7
in reply to: hugo7
oDoc = ThisDoc.Document
  'check if the part is a sheet metal part
  If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
    oDoc = ThisApplication.ActiveDocument
    Dim oCompDef As SheetMetalComponentDefinition
    oCompDef = oDoc.ComponentDefinition
    If oCompDef.HasFlatPattern = False Then
        oCompDef.Unfold
    Else
        oCompDef.FlatPattern.Edit
    Dim sOut As String
    Dim oPath As String
    oPath = ThisDoc.Path & "\DXF Flat & Step"
    If Not System.IO.Directory.Exists(oPath) Then
        System.IO.Directory.CreateDirectory(oPath)
    Dim sFname As String
    sOut = "FLAT PATTERN DXF?AcadVersion=2004&RebaseGeometry=True&OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0;0;0;IV_OUTER_PROFILE;IV_INTERIOR_PROFILES;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL&InvisibleLayers=IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES;IV_BEND;IV_BEND_DOWN"
    sFname = oPath & "test"& ".dxf"
    oCompDef.DataIO.WriteDataToFile(sOut, sFname)
    'MessageBox.Show("Your file was saved in the following dirctory: " + sFname)
  Else
    'MessageBox.Show("Only sheet metal parts can be exported as DXF. Nice Try! :-)")
sebastien_forman
in reply to: hugo7
hello, try that
' Check if the part is a sheet metal part
    ' Check if the part has a flat pattern
    If Not oCompDef.HasFlatPattern Then
        oCompDef.Unfold
    Else
    Dim oPath As String
    ' Check if the output directory exists, if not, create it
    sFname = oPath & "\"&ThisDoc.FileName &"_flat.dxf" ' Correctly formatted DXF file path
    ' Define parameters for DXF export
    Dim sOut As String
    ' Export the sheet metal part as a DXF file
Else
    ' Display a message if the part is not a sheet metal part
    MessageBox.Show("Only sheet metal parts can be exported as DXF.")
hugo7
in reply to: hugo7
Thank that works fine
now can you make this rule to save at the same doc ?
i need to generate a dxf and a .step or combine the 2 rules if its possible ?
' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
    ' Set application protocol.
    ' 2 = AP 203 - Configuration Controlled Design
    ' 3 = AP 214 - Automotive Design
    oOptions.Value("ApplicationProtocolType") = 3
    ' Other options...
    'oOptions.Value("Author") = ""
    'oOptions.Value("Authorization") = ""
    'oOptions.Value("Description") = ""
    'oOptions.Value("Organization") = ""
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oData As DataMedium
    oData = ThisApplication.TransientObjects.CreateDataMedium
    oData.FileName = ThisDoc.PathAndFileName(False) & ".stp"
oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
sebastien_forman
in reply to: hugo7
try that 😉
Sub main()
    ' Get the active document
        ' Set the active document as the current document
            oCompDef.Unfold
        Else
        ' Define the output directory path
        Dim oPath As String
        ' Define the DXF file name and path
        Dim sOut As String
        ' Export STEP
        ExportStep(oPath, ThisDoc.FileName)
    Else
End Sub
Function ExportStep(ByVal oPath As String, ByVal fileName As String)
    ' Set the STEP file folder
    oFolder = oPath
    ' Check for the STEP folder and create it if it does not exist
    If Not System.IO.Directory.Exists(oFolder) Then
        System.IO.Directory.CreateDirectory(oFolder)
    ' Check if the translator has save copy options
    If oSTEPTranslator.HasSaveCopyAsOptions(ThisDoc.Document, oContext, oOptions) Then
        oOptions.Value("ApplicationProtocolType") = 3 ' 3 = AP 214 - Automotive Design
        ' Set the context type
        ' Create a data medium
        ' Set the STEP file name and path
        oData.FileName = oFolder & "\" & fileName & "-flat.stp"
        ' Save the part as a STEP file
        oSTEPTranslator.SaveCopyAs(ThisDoc.Document, oContext, oOptions, oData)
End Function
hugo7
in reply to: hugo7
thank you very helpfull
have a good one !
Technology Administrators
