Dears,
Happy New Year! to Everyone...
I'm trying to add a dynamic button in Quick Access Button as this Design Doctor Button. So when I open an item (Part/Assembly/Drawing) It'll checking something and return the result by visible/highlight button icon.
I mean it'll working:
1. After opened an item (part/assembly/drawing...) button icon show a warning and show this icon
2. If everything are fixed/nothing wrong it'll show this icon
Please help me the guide how to do that. Thank you very much!
I can help you writing an add in...
You need to change the icon to achieve this.
Let me know if an add in is ok.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Could you send me the two different icons either per private message or via this forum?
And also the conditions for each icon.
Arthur Knoors
I think you need something similar to this.
The button Green will get Red if the file is Dirtied and need a save.
The button Red will get Green again after save of the file.
Please watch the movie....
Arthur Knoors
Yes, I'm finding something like it, that can change button icon dynamic.
Thanks!
I can't send files direct from private message,
Could you try with any icon that you have?
sure take a look at the MP4
Arthur Knoors
Arthur Knoors
My trigger would be whenever a new document of a particular part is created.
For example when a new sheet metal document is created, enable a particular button. The button should be disabled in all other documents (including old sheet metal documents).
Means:
Only If a new sheet-metal part file is created the button must be Green.
For all other parts it must be Red, Include old (non new) sheet metal parts.
For non new parts the button must also be Green.
Is this correct?
Arthur Knoors
Dear @bradeneuropeArthur ,
I wanna it check something as the template when item opened. Ex: List of users parameter/kind of item; Dim overrides in drawing; Scale that used of all views are in Standard?... After checked/fixed and saved it'll return done icon.
Maybe I'll have some idea, but at the moment I wanna got solution to change icon as your video shown.
Thanks!
Hi @bradeneuropeArthur
Could you please help us to share the code that can change the icon as your video?
I'll try to do the conditions to change the icon by myself.
I have send you a PM with some additional questions.
Arthur Knoors
@abdullah_elq wrote:
This looks pretty awesome. How did you program that?
Do you also need support same as @ngnam1988 does?
Arthur Knoors
I can control enable/disable buttons (enable after something is checked) - but can't change them as your shown.
-Quick Access Toolbar
-Ribbon Tabs
Could you guide to me how to do it? Thanks,
I have asked/send you a while ago per message if you can send me the content of your add-in file.
Did not get a reply from you.
If I have that I can update and you can paste it in your code.
Please see your message...
Arthur
Arthur Knoors
