Demote Frame Member through API
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Did anyone try to demote a frame member through API?
I tried with command manager:
ThisApplication.SilentOperation = True Dim oCM As CommandManager Set oCM = ThisApplication.CommandManager ' Prepopulate the file name of new component in ' the 'Create Component' dialog oCM.PostPrivateEvent kFileNameEvent, "C:\temp\test\demoted.iam" Dim oControlDef As ControlDefinition Set oControlDef = oCM.ControlDefinitions("AssemblyDemoteCmd") ' Execute the demote command oControlDef.Execute ThisApplication.SilentOperation = False
I also tried with this example:
Public Sub Demote() ' Get the active assembly document Dim oDoc As AssemblyDocument Set oDoc = ThisApplication.ActiveDocument Dim oDef As AssemblyComponentDefinition Set oDef = oDoc.ComponentDefinition ' Get the occurrence to be demoted Dim oOcc As ComponentOccurrence Set oOcc = oDef.Occurrences.Item(1) ' Create a new sub-assembly to demote the occurrence into Dim oNewSubAssy As AssemblyDocument Set oNewSubAssy = ThisApplication.Documents.Add(kAssemblyDocumentObject, , False) Dim oMat As Matrix Set oMat = ThisApplication.TransientGeometry.CreateMatrix ' Create an instance of the new sub-assembly Dim oSubAssyOcc As ComponentOccurrence Set oSubAssyOcc = oDef.Occurrences.AddByComponentDefinition(oNewSubAssy.ComponentDefinition, oMat) ' Get the model browser Dim oPane As BrowserPane Set oPane = oDoc.BrowserPanes.Item("Model") ' Get the browser node that corresponds to the new sub-assembly occurrence Dim oSubAssyNode As BrowserNode Set oSubAssyNode = oPane.GetBrowserNodeFromObject(oSubAssyOcc) ' Get the last visible child node under the sub-assembly occurrence Dim oTargetNode As BrowserNode Dim i As Long For i = oSubAssyNode.BrowserNodes.Count To 1 Step -1 If oSubAssyNode.BrowserNodes.Item(i).Visible Then Set oTargetNode = oSubAssyNode.BrowserNodes.Item(i) Exit For End If Next ' Get the browser node that corresponds to the occurrence to be demoted Dim oSourceNode As BrowserNode Set oSourceNode = oPane.GetBrowserNodeFromObject(oOcc) ' Demote the occurrence Call oPane.Reorder(oTargetNode, False, oSourceNode) End Sub
But no luck, it won't demote.
Same codes work in a standard assembly.
Any advice?
Autodesk Inventor 2015 Certified Professional
