Delete excel Documents from your project folder
2 REPLIES 2
ndillner343SKL
195 Views, 2 Replies
I'm looking to delete an excel document (.xlsx) from my project folder.
This is my best attempt,
	'define the file to create/open
	myXLS_File = ThisDoc.Path & "\TempFile.xlsx"
'define Excel Application object
	excelApp = CreateObject("Excel.Application")
'set Excel to run visibly, change to false if you want to run it invisibly
	excelApp.Visible = False
'suppress prompts (such as the compatibility checker)
	excelApp.DisplayAlerts = False
	excelWorkbook = excelApp.Workbooks.Delete(myXLS_File)
2 REPLIES 2
if this is iLogic:
If System.IO.File.Exists(myXLS_File) Then
    System.IO.File.Delete(MyXLS_File)
End if
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Reset view Representations | Smart Leader | Copy with Constraints | Part Visibility Utility | Property Editor | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle
In addition on @basautomationservices reply. You can use the function IO.Path.Combine(...) This function will add \ in your path if needed. (I see that you hard coded them in your OP) Because that function will look automatically for you if \ are needed it's less likely for you to get bugs.
Another thing I like is the FileInfo class. It has all kinds functions that you might need. Your could could look like this.
[iLogic code]
Dim excelFilePath = System.IO.Path.Combine(ThisDoc.Path, "TempFile.xlsx")
Dim excelFileInfo As New System.IO.FileInfo(excelFilePath)
If (excelFileInfo.Exists) Then excelFileInfo.Delete()
Jelte de Jong
Blog: hjalte.nl - github.com
Technology Administrators
