I'm looking to delete an excel document (.xlsx) from my project folder.
This is my best attempt,
'define the file to create/open myXLS_File = ThisDoc.Path & "\TempFile.xlsx" 'define Excel Application object excelApp = CreateObject("Excel.Application") 'set Excel to run visibly, change to false if you want to run it invisibly excelApp.Visible = False 'suppress prompts (such as the compatibility checker) excelApp.DisplayAlerts = False excelWorkbook = excelApp.Workbooks.Delete(myXLS_File)
Solved by JelteDeJong. Go to Solution.
Solved by basautomationservices. Go to Solution.
if this is iLogic:
If System.IO.File.Exists(myXLS_File) Then
System.IO.File.Delete(MyXLS_File)
End if
In addition on @basautomationservices reply. You can use the function IO.Path.Combine(...) This function will add \ in your path if needed. (I see that you hard coded them in your OP) Because that function will look automatically for you if \ are needed it's less likely for you to get bugs.
Another thing I like is the FileInfo class. It has all kinds functions that you might need. Your could could look like this.
[iLogic code]
Dim excelFilePath = System.IO.Path.Combine(ThisDoc.Path, "TempFile.xlsx") Dim excelFileInfo As New System.IO.FileInfo(excelFilePath) If (excelFileInfo.Exists) Then excelFileInfo.Delete()
Jelte de Jong
Blog: hjalte.nl - github.com
