Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Problem with Ilogic detecting parts/drawing relationship
3 REPLIES 3
matthewZYUPT
250 Views, 3 Replies
Using code from 2 separate Ilogics, I've been able to automatically print "simple" parts of an assembly and the top level assembly drawing but it has some limitations, for some reason its unable to print drawings for these "raw" frame pieces and this Ipart (has different part# depending on configuration (I suspect that it's not grabbing it because somewhere in the code it associates drawings based on the part name/possibly file name)) would someone be able to review these 2 parts and Ilogic to see why it is unable to detect the drawings for them? any help would be greatly appreciated, thanks!
 VV--START OF ILOGIC HERE--VV
' This is print all the associated dwg of an assembly to PDF.  This is similar to the "Print all Ref dwg" macro functionality, but' it is now converted into a iLogic rule. This assumes that the dwg is the same file name as the part or the assembly.'There are a few changes to the orginal Macro:' 1. Now have an option to print in color or B/W.' 2. The ilogic code also prints the top level assembly.' ----------------------------------------------------------------Kirk Arthur 8/30/2016
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'get user input
RUsure = MessageBox.Show ( _
"This will create a PDF file for all of the assembly components that have" _
& vbLf & "drawings files. This rule expects that the drawing file shares the same" _
& vbLf & " name and location as the component." _
& vbLf & "" _
& vbLf & "Make sure the file extensions are set to Visible in Windows Explorer." _
& vbLf & "" _
& vbLf & "This could take a while.  Are you sure you want to do this?" _
& vbLf & "" _
& vbLf & "", "iLogic  - Batch Output PDFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
'- - - - - - - - - - - - -PDF setup - - - - - - - - - - - -
        MsgBox ("This is NOT an assembly document!")
        Exit Sub
    Dim oPrintMgr As PrintManager
    oPrintMgr = ThisApplication.ActiveDocument.PrintManager
    If MsgBox("Using Printer " & oPrintMgr.Printer & ", Best Fit, 11x17 paper, Landscape Mode." _
    & vbLf & " " _
    & vbLf & " Do you want to continue?"     ,vbYesNo + vbQuestion,"System Printer Settings ") = vbNo Then
        Exit Sub
    Dim oDrgPrintMgr As DrawingPrintManager
    'MsgBox ("Using Printer " & oPrintMgr.Printer & ", Best Fit, 11x17 paper, Landscape Mode.")
    dirPath = Left(oAsmDoc.FullFileName, Len(oAsmDoc.FullFileName) - Len(oAsmDoc.DisplayName))
' ----Determine if the prints should be in color or B/W ------
    oColorAsBlack="False"
    RUsure = MessageBox.Show ( "Do you want to print this in COLOR?"& vbLf & "", "Color or B/W Prints",MessageBoxButtons.YesNo)
    oColorAsBlack="True"
    'Return
    Else
    Dim oRefDocs As DocumentsEnumerator
    oRefDocs = oAsmDoc.AllReferencedDocuments
    Dim oRefDoc As Document
    numFiles = 0
''End If
'get PDF target folder path
oFolder = oPath & "\" & oAsmName & " PDF Files"
'Check for the PDF folder and create it if it does not exist'If Not System.IO.Directory.Exists(oFolder) Then
    'System.IO.Directory.CreateDirectory(oFolder)'End If
'- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -'look at the files referenced by the assembly
For Each oRefDoc In oRefDocs
        dwgPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "dwg"
        If (System.IO.File.Exists(dwgPathName)) Then
            numFiles = numFiles + 2
            'If numFiles = 10 Then Exit Sub
        Dim oDrawDoc As DrawingDocument
            oDrawDoc = ThisApplication.Documents.Open(dwgPathName, True)
            oDrawDoc.Activate
            oDrawDoc = ThisApplication.ActiveDocument
            oDrgPrintMgr = oDrawDoc.PrintManager
            oDrgPrintMgr.AllColorsAsBlack = oColorAsBlack
            oDrgPrintMgr.ScaleMode = kPrintBestFitScale
            ' Printer setup, default printer
            'oPrintMgr.ColorMode = kPrintDefaultColorMode ' Set to default. Uses printer settings
            oPrintMgr.PrintRange = kPrintAllSheets 'Prints all sheets in the dwg.
            oPrintMgr.NumberOfCopies = 1 ' Set to print one copies.
            oPrintMgr.Orientation = kLandscapeOrientation ' Set to print using landscape orientation.
            oPrintMgr.PaperSize = kPaperSizeTabloid 'Set the paper size.
            oPrintMgr.SubmitPrint ' Submit the print.
            oDrawDoc.Close (True)
 Next
        'MsgBox ("There are " & numFiles & " sent to printer.")
'- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - -
oAsmDrawing = ThisDoc.ChangeExtension(".dwg")
If (System.IO.File.Exists(oAsmDrawing)) Then
oAsmDrawingDoc = ThisApplication.Documents.Open(oAsmDrawing, True)
oAsmDrawingName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -3)
'write out the PDF for the Top Level Assembly Drawing file
            oAsmDrawDoc = ThisApplication.Documents.Open(oAsmDrawing, True)
            oAsmDrawDoc.Activate
            oDrgPrintMgr = oAsmDrawDoc.PrintManager
            oAsmDrawDoc.Close (True)
  numFiles = numFiles + 1
  Else
      MessageBox.Show (" No DWG of the Top level file found!" _
    & vbLf & " " _
    & vbLf & "There were " & numFiles & " files sent to the printer."," Job Complete ")
  Return
MessageBox.Show ("There were " & numFiles & " files sent to the printer."," Job Complete ")
'MessageBox.Show("New Files Created in: " & vbLf & dwgpathname, "iLogic")'open the folder where the new ffiles are saved'Shell("explorer.exe " & oFolder,vbNormalFocus)
3 REPLIES 3
A.Acheson
in reply to: matthewZYUPT
I had a quick look and here is the business end for getting the drawing for the referenced documents.
This will get the FullDocument name of the file which is the logical path to open either the part/assembly. The left function counts from the left a number of characters and the Len function counts the number of characters in a given string. The combined left function removes the “ipt” /“iam” and then “dwg”  is added on the end.
So relating to your issue, is the drawing located in the same folder as the referenced part/assembly? If not this is why it fails to print.
Regards
Alan
matthewZYUPT
in reply to: A.Acheson
I've checked this and it appears all the drawings are in the same folder as the parts and are still not printing, it is also getting drawings for parts that are NOT in the same folder.
A.Acheson
You have a little mystery so. I won't be able to test for a while. Can you try just paste this in a new rule and for the non printing drawings supply the drawingPathName and open them directly to encounter any errors in paths etc.
         Dim dwgPathName As String = "C\EnterName.dwg" 'change here
            oDrawDoc.Activate
Regards
Alan
Technology Administrators
