Could you please try to explain a little more what you are trying to achieve.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Arthur Knoors
Arthur Knoors
Arthur Knoors
Arthur Knoors
Arthur Knoors
Arthur Knoors
Arthur Knoors
Arthur Knoors
The following works for me:
Dim apprentice As New ApprenticeServerComponent ' Open a document. Dim doc As ApprenticeServerDocument
doc = apprentice.Open("C:\Vault\Projects\Part1.ipt")'YOUR FILE FULL NAME HERE ' Get the thumbnail image. Dim thumbnail As stdole.IPictureDisp thumbnail = doc.Thumbnail ' Convert the IPictureDisp object to an Image. Dim img As Image = Compatibility.VB6.IPictureDispToImage(thumbnail) ' Display the image in the picture box. PICTUREBOX OF YOUR FORM PictureBox1.Image = img
Arthur Knoors
Arthur Knoors
Wow, so much text and „advice“ for a simple question: „Why the function CreateImage doesn’t work“. It doesn’t work here neither and “solution” over thumbnail is NO SOLUTION. So anyone from Autodesk here who can provide .NET example of the function or tell us why it doesn’t work the way it should?
