Hi there
We would like to be able to access all of filenames from the available Content Centre parts, Excel or the likes.
The reason being we have many duplicate parts in our outdated Access database and Vault. I'd love to be able to tidy this up by pointing the duplicates to the Content Centre part i.e. "do not use, use ********* from Content Centre".
If anybody could help me I'd be most appreciative.
Solved by MechMachineMan. Go to Solution.
So if I understand correct, you want to have a list of each part thats in the content center? Not a list for each content center family?
Yes that is correct.
I'd like to be able to access the filename and part number properties and have them appear in a list, preferably under the categories/families in which they are contained.
Is this possible?
I would say yes, but I can't seem to find a way to loop all families in the content center?
Really appreciate you having a look at this for me though.
I've introduced the Content Centre to the company but I've been forced to work in conjunction with the unadministered system they have ran here for years.
This would be a massive help to me.
You know that the list will be LONG, and I mean really LONG, I'm exporting mine as a test for the code but ugghhh it takes long 😄
But I guess it works, I will let you know.
I'll be doing it only for my library so, although it will be big, it'll not be for the entire Content Centre big.
Then you will need to disable the undesired content center files in your project file.
Do you know how-to make a standalone .exe? Then I can just give you the code and you can implement it, or do you want me to make a exe and send it to you?
Above me I'm afraid but if you could send me one that would be absolutely excellent, thanks.
Really good of you.
By the way I only have the desired library available in my project file so no worries there.
Here is the code I used, did not have time to make a plugin .exe for it..
Private Families As List(Of Family) Private Sub ContentCheck_Click(sender As Object, e As EventArgs) Handles ContentCheck.Click Dim oContentCenter As ContentCenter oContentCenter = oInvApp.ContentCenter Families = New List(Of Family) ReadContentCenter(oContentCenter.TreeViewTopNode) ListToExcel() End Sub Private Class FamilyMember Public Property FileName Public Property PartNumber Public Property AXCode End Class Private Class Family Public Property Name Public Property Members As List(Of FamilyMember) Public Sub New() Members = New List(Of FamilyMember) End Sub End Class Private Sub ReadContentCenter(ByVal Node As ContentTreeViewNode) For Each oNode As ContentTreeViewNode In Node.ChildNodes Debug.Print(oNode.DisplayName) ' Check if there are families If oNode.Families.Count > 0 Then ' Loop all the families in the node For Each oFamily As ContentFamily In oNode.Families Debug.Print(oFamily.DisplayName) Dim Family As New Family Family.Name = oFamily.DisplayName Dim oColumnNumber(2) As Integer oColumnNumber = GetColumnNumbers(oFamily) ' Loop all the family member For Each oMember As ContentTableRow In oFamily.TableRows Dim FamilyMember As New FamilyMember Try Debug.Print(oMember.GetCellValue(oColumnNumber(0))) FamilyMember.FileName = oMember.GetCellValue(oColumnNumber(0)) Catch ex As Exception FamilyMember.FileName = "#N/A" End Try Try FamilyMember.PartNumber = oMember.GetCellValue(oColumnNumber(1)) Catch ex As Exception FamilyMember.PartNumber = "#N/A" End Try Try FamilyMember.AXCode = oMember.GetCellValue(oColumnNumber(2)) Catch ex As Exception FamilyMember.AXCode = "#N/A" End Try Family.Members.Add(FamilyMember) Next Families.Add(Family) Next End If ' Check if there are more child nodes If oNode.ChildNodes.Count > 0 Then ' Recursivly search for more nodes ReadContentCenter(oNode) End If Next End Sub Private Function GetColumnNumbers(ByVal oFamily As ContentFamily) As Integer() Dim oColumnNumbers(2) As Integer Dim oFlag(2) As Boolean oFlag(0) = False oFlag(1) = False oFlag(2) = False ' Loop all columns For i As Integer = 1 To oFamily.TableColumns.Count If oFamily.TableColumns.Item(i).InternalName = "FILENAME" Then oColumnNumbers(0) = i oFlag(0) = True ElseIf oFamily.TableColumns.Item(i).InternalName = "PARTNUMBER" Then oColumnNumbers(1) = i oFlag(1) = True ElseIf oFamily.TableColumns.Item(i).InternalName = "AX_CODE" Then oColumnNumbers(2) = i oFlag(2) = True End If If oFlag(0) And oFlag(1) And oFlag(2) Then Exit For End If Next GetColumnNumbers = oColumnNumbers End Function Private Sub ListToExcel() ' Set reference to the currently active excel application Dim oExcel As Microsoft.Office.Interop.Excel.Application = System.Runtime.InteropServices.Marshal.GetActiveObject("Excel.Application") ' Set reference to the currently active excel workbook ( 1 workbook open ?? ) Dim oWorkbook As Workbook oWorkbook = oExcel.Workbooks.Item(1) ' Set reference to the correct worksheet Dim oSheet As Worksheet oSheet = oWorkbook.Sheets.Item(1) ' Row count Dim oCount As Integer = 2 For Each Family In Families For Each FamilyMember In Family.Members oSheet.Range("A" & oCount).Value = Family.Name oSheet.Range("B" & oCount).Value = FamilyMember.FileName oSheet.Range("C" & oCount).Value = FamilyMember.PartNumber oSheet.Range("D" & oCount).Value = FamilyMember.AXCode ' Add to the count oCount += 1 Next Next End Sub
I'd like to resurrect this one if I may please.
How would I run this code? plugin .exe's are well over my head I'm afraid.
Could anyone help me with getting this one to run please? It is becoming increasingly important for me to be able to access all part numbers from content centre in a complete list.
Run this in a rule.
Private Sub Main() Dim oInvApp As Inventor.Application = ThisApplication Dim oContentCenter As ContentCenter oContentCenter = oInvApp.ContentCenter Families = New List(Of Family) ReadContentCenter (oContentCenter.TreeViewTopNode) ListToExcel() End Sub Private Families As List(Of Family) Private Class FamilyMember Public Property FileName Public Property PartNumber Public Property Description End Class Private Class Family Public Property Name Public Property Members As List(Of FamilyMember) Public Sub New() Members = New List(Of FamilyMember) End Sub End Class Private Sub ReadContentCenter(ByVal Node As ContentTreeViewNode) For Each oNode As ContentTreeViewNode In Node.ChildNodes If oNode.Families.Count > 0 Then For Each oFamily As ContentFamily In oNode.Families Dim Family As New Family Family.Name = oFamily.DisplayName Dim oColumnNumber(2) As Integer oColumnNumber = GetColumnNumbers(oFamily) For Each oMember As ContentTableRow In oFamily.TableRows Dim FamilyMember As New FamilyMember Try FamilyMember.FileName = oMember.GetCellValue(oColumnNumber(0)) Catch ex As Exception FamilyMember.FileName = "#N/A" End Try Try FamilyMember.PartNumber = oMember.GetCellValue(oColumnNumber(1)) Catch ex As Exception FamilyMember.PartNumber = "#N/A" End Try Try FamilyMember.Description = oMember.GetCellValue(oColumnNumber(2)) Catch ex As Exception FamilyMember.Description = "#N/A" End Try Family.Members.Add (FamilyMember) Next Families.Add (Family) Next End If If oNode.ChildNodes.Count > 0 Then ReadContentCenter (oNode) End If Next End Sub Private Function GetColumnNumbers(ByVal oFamily As ContentFamily) As Integer() Dim oColumnNumbers(2) As Integer Dim oFlag(2) As Boolean oFlag(0) = False oFlag(1) = False oFlag(2) = False For i As Integer = 1 To oFamily.TableColumns.Count If oFamily.TableColumns.Item(i).InternalName = "FILENAME" Then oColumnNumbers(0) = i oFlag(0) = True ElseIf oFamily.TableColumns.Item(i).InternalName = "PARTNUMBER" Then oColumnNumbers(1) = i oFlag(1) = True ElseIf oFamily.TableColumns.Item(i).InternalName = "DESCRIPTION" Then oColumnNumbers(2) = i oFlag(2) = True End If If oFlag(0) And oFlag(1) And oFlag(2) Then Exit For End If Next GetColumnNumbers = oColumnNumbers End Function Private Sub ListToExcel() Dim oExcel As Object = CreateObject("Excel.Application") oExcel.Visible = True Dim oWorkbook As Object oWorkbook = oExcel.Workbooks.Add() Dim oSheet As Object oSheet = oWorkbook.Sheets.Item(1) Dim oCount As Integer = 2 For Each Family In Families For Each FamilyMember In Family.Members oSheet.Range("A" & oCount).Value = Family.Name oSheet.Range("B" & oCount).Value = FamilyMember.FileName oSheet.Range("C" & oCount).Value = FamilyMember.PartNumber oSheet.Range("D" & oCount).Value = FamilyMember.Description oCount = oCount + 1 Next Next oExcel = Nothing End Sub
I can't thank you both enough for taking the time to help, this is exactly what I need.
Thank you very much.
@MechMachineMan thanks for finishing the code so @Anonymous can use it. I am just swamped here and don't have time to write it adjust it..
I have a similar issue as the original poster. I would like to make an excel spread sheet with the following columns:
Family name (not really that important but it would be nice)
Part number
description
I ran the code presented above and it worked very well except for the descriptions when came up #N/A which from looking at the code means that there was an exception on this line.
I could also export the display name on the parts as well, as that is linked to the description. Could someone guide me to where I need to change things in the code to make that happen?
I have included screen shots of the description column and the designation column.
@MechMachineMan wrote:Run this in a rule.
Could anyone help my if I want to adapt the code to include custom column like "PTN_ARTNR" and "PTN_SIZE", they are 2 custom iproperties that exists in all CC parts. It would save us a lot of work. Many Thanks, Johan
I've tried this code but it stops after listing fasteners family in our library with the error message "Exception from HRESULT: 0x800AC472".
The fastener count is about 16.5k could that be the problem ?
Any idea why it stops so soon ?
We need to capture data from the structural shapes & tube and pipe families too.
Any advice would be greatly appreciated.
Here is the output. The trick here is to follow the pattern laid out by the previous columns. Pay special attention to numbers as they will be your index in for loops. I would suggest to create a new project with a custom library and with one family to test your output. Otherwise you could get too much data and not the outcome you want. Alternatively place an if statement to search for a specific family name bypassing other families.
Here is the modified code
Private Sub Main() Dim oInvApp As Inventor.Application = ThisApplication Dim oContentCenter As ContentCenter oContentCenter = oInvApp.ContentCenter Families = New List(Of Family) ReadContentCenter (oContentCenter.TreeViewTopNode) ListToExcel() End Sub Private Families As List(Of Family) Private Class FamilyMember Public Property FileName Public Property PartNumber Public Property Description Public Property PTN_ARTNR Public Property PTN_SIZE End Class Private Class Family Public Property Name Public Property Members As List(Of FamilyMember) Public Sub New() Members = New List(Of FamilyMember) End Sub End Class Private Sub ReadContentCenter(ByVal Node As ContentTreeViewNode) For Each oNode As ContentTreeViewNode In Node.ChildNodes If oNode.Families.Count > 0 Then For Each oFamily As ContentFamily In oNode.Families Dim Family As New Family Family.Name = oFamily.DisplayName Dim oColumnNumber(4) As Integer oColumnNumber = GetColumnNumbers(oFamily) For Each oMember As ContentTableRow In oFamily.TableRows Dim FamilyMember As New FamilyMember Try FamilyMember.FileName = oMember.GetCellValue(oColumnNumber(0)) Catch ex As Exception FamilyMember.FileName = "#N/A" End Try Try FamilyMember.PartNumber = oMember.GetCellValue(oColumnNumber(1)) Catch ex As Exception FamilyMember.PartNumber = "#N/A" End Try Try FamilyMember.Description = oMember.GetCellValue(oColumnNumber(2)) Catch ex As Exception FamilyMember.Description = "#N/A" End Try Try FamilyMember.PTN_ARTNR = oMember.GetCellValue(oColumnNumber(3)) Catch ex As Exception FamilyMember.PTN_ARTNR = "#N/A" End Try Try FamilyMember.PTN_SIZE = oMember.GetCellValue(oColumnNumber(4)) Catch ex As Exception FamilyMember.PTN_SIZE = "#N/A" End Try Family.Members.Add (FamilyMember) Next Families.Add(Family) Next End If If oNode.ChildNodes.Count > 0 Then ReadContentCenter (oNode) End If Next End Sub Private Function GetColumnNumbers(ByVal oFamily As ContentFamily) As Integer() Dim oColumnNumbers(4) As Integer Dim oFlag(4) As Boolean oFlag(0) = False oFlag(1) = False oFlag(2) = False oFlag(3) = False oFlag(4) = False For i As Integer = 1 To oFamily.TableColumns.Count If oFamily.TableColumns.Item(i).InternalName = "FILENAME" Then oColumnNumbers(0) = i oFlag(0) = True ElseIf oFamily.TableColumns.Item(i).InternalName = "PARTNUMBER" Then oColumnNumbers(1) = i oFlag(1) = True ElseIf oFamily.TableColumns.Item(i).InternalName = "DESCRIPTION" Then oColumnNumbers(2) = i oFlag(2) = True ElseIf oFamily.TableColumns.Item(i).InternalName = "PTN_ARTNR" Then oColumnNumbers(3) = i oFlag(3) = True ElseIf oFamily.TableColumns.Item(i).InternalName = "PTN_SIZE" Then oColumnNumbers(4) = i oFlag(4) = True End If If oFlag(0) And oFlag(1) And oFlag(2) And oFlag(3) And oFlag(4) Then Exit For End If Next GetColumnNumbers = oColumnNumbers End Function Private Sub ListToExcel() Dim oExcel As Object = CreateObject("Excel.Application") oExcel.Visible = True Dim oWorkbook As Object oWorkbook = oExcel.Workbooks.Add() Dim oSheet As Object oSheet = oWorkbook.Sheets.Item(1) oSheet.Range("A1").Value = "Family Name" oSheet.Range("B1").Value = "FileName" oSheet.Range("C1").Value = "PartNumber" oSheet.Range("D1").Value = "Description" oSheet.Range("E1").Value = "PTN_ARTNR" oSheet.Range("F1").Value = "PTN_SIZE" Dim oCount As Integer = 2 For Each Family In Families For Each FamilyMember In Family.Members oSheet.Range("A" & oCount).Value = Family.Name oSheet.Range("B" & oCount).Value = FamilyMember.FileName oSheet.Range("C" & oCount).Value = FamilyMember.PartNumber oSheet.Range("D" & oCount).Value = FamilyMember.Description oSheet.Range("E" & oCount).Value = FamilyMember.PTN_ARTNR oSheet.Range("F" & oCount).Value = FamilyMember.PTN_SIZE oCount = oCount + 1 Next Next oExcel = Nothing End Sub
Thanks AA,
That works pretty well for me - but i got my terminology wrong.
I want to be able to loop through all the content centre categories too. Is that even possible ?
