Copy a sheet from another drawing
10 REPLIES 10
Message 1 of 11
AMN3161
965 Views, 10 Replies
Hello anyone have a rule that will copy a specific sheet from a specific drawing and insert it into the active drawing? I am trying to get around some of the limitations with Inventor Template files
thank you in advanced
10 REPLIES 10
Message 2 of 11
https://forums.autodesk.com/t5/inventor-customization/ilogic-copy-drawing-sheet-from-one-drawing-to-...
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Message 3 of 11
This is what i originally tried but i was having difficulty getting it to work
Message 4 of 11
J-Camper
in reply to: AMN3161
@AMN3161,
Did you modify the code from the other forum post?  Can you post your modified version of the code?
What kind of difficulties are you having?
Message 5 of 11
AMN3161
in reply to: J-Camper
I am probably missing something stupid, i am new to ilogic
the drawing i want the sheet copied from is C:\_VAULT_WORKSPACE\JOBS\Templates\tag Testing (Tony).idw
The Sheet I want is called "Tags" on the above drawing
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
	MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Drawing Documents.",vbOK, "WRONG DOCUMENT TYPE")
	Return
End If
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oOtherDocPath As String = "C:\_VAULT_WORKSPACE\JOBS\Templates\tag Testing (Tony).idw"
Dim oOtherDrawing As DrawingDocument = ThisApplication.Documents.Open(oOtherDocPath,False)
For Each oSheet As Sheet In oDDoc.Sheets
	If oSheet.Name.Contains("Tags") Then
		oSheet.CopyTo(oOtherDrawing)
	End If
Next
Message 6 of 11
JhoelForshav
@AMN3161
It looks like you just got the two drawing documents mixed up.
Is this what you want? 🙂
	Return
End If
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oOtherDrawing As DrawingDocument = ThisApplication.Documents.Open(oOtherDocPath, False)
For Each oSheet As Sheet In oOtherDrawing.Sheets
	If oSheet.Name.StartsWith("Tags") Then oSheet.CopyTo(oDoc)
Next
oDoc.Update
ThisApplication.Documents.CloseAll(True)
Message 7 of 11
J-Camper
@AMN3161,
It was pretty simple, you just needed to swap with drawing to look through and which drawing to copy to:
	Return
End If
		oSheet.CopyTo(oDDoc)
	End If
Next
Message 8 of 11
J-Camper
in reply to: JhoelForshav
@JhoelForshav,
Looks like you were quicker on this one too haha
Message 9 of 11
AMN3161
I see, thank you for the help!
Message 10 of 11
JhoelForshav
Hahah, sorry @J-Camper , but at least both our answers got accepted as solutions 😄
Message 11 of 11
J-Camper
Yeah no worries @JhoelForshav , I thought it was funny to happen twice within the hour haha
