Content Centre Customisation
maheshbhojkar
Message 1 of 18
maheshbhojkar
Dear All, I have created a content centre library customised for my organisation (Find attachment).  i have created for Pipe segment & its working good except for 3 inch schedule 40. lengths for other pipes are changing while placing from content centre but the mentioned pipe length remains unchanged for 50 inches
Replies (17)
Message 2 of 18
maheshbhojkar
No reply for above query???Smiley Indifferent
Message 3 of 18
bradeneuropeArthur
the file cannot be opened without having the ANSI lib file.
So please upload the ANSI Lib Too
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 18
maheshbhojkar
ANSI lib file size is too much big (1.35 GB) I am not able to upload, but please find attached image file for uploaded library file previously. Filter group name & standard organisation should be selected as per marked in image. If it not works i will upload file.
Message 5 of 18
bradeneuropeArthur
I can not use it because inventor gives error about missing reference!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 18
maheshbhojkar
I tried to upload file but its size is too much that it exceeds limit of allowed file size to upload.
Message 7 of 18
bradeneuropeArthur
I found what the issue is:
  • In the parameter table there is no key defined for the PL value.
  • The parameter L was mapped. make that value empty.
  • Delete all your written text for the file name (Blue) text to black text. this means that the expression is calculated and not the written text.
I can upload the changed library if you want but it has been migrated to 2018 inventor.
please let me know.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 18
maheshbhojkar
you mentioned 3 points, I am not able to understand the last point (delet text...).
I am working with inventor 2015 version, 2018 version will not be work with it. Thank you for your support. looking forward for your guidance.
Message 9 of 18
bradeneuropeArthur
Select all text in the table for the filename column only and press delete.
the values will be calculated new and are correct.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 18
maheshbhojkar
Smiley Happy Thanks Buddy. It worked finally.....
Will disturb you again (I am creating content centre for my organisation. for all components).
Message 11 of 18
bradeneuropeArthur
No problem.
I appreciate that!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 18
maheshbhojkar
as per earlier discussions, the files are working in assembly. Part nos. of pipe feature are appearing in BOM of assembly, but if we use same pipe/ tube in tubing & piping feature in inventor, it shows blank in BOM. We need to input part nos. manually to get quantity of pipe. Need your assistance.
Message 13 of 18
bradeneuropeArthur
You mean when using the frame-generator or what?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 18
bradeneuropeArthur
You need to change this is your "DESIGNATION" properties:
DESIGNATION PROPERTIESDESIGNATION PROPERTIES
This should solve it.
WHY IS THAT:
Because the information is only read from the family so is actually fix.
But you use the inventor features like "Frame gen." or "tube and Pipe", so the values are never selected from the selection table.
This is why the {P_L} is not working and the = ##### <P_L> is working.
if you need more assistant please let me know.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 18
maheshbhojkar
Please find attached image. when I use pipe in assembly directly, BOM shows item no. for that pipe. But when I go through the tube & pipe feature & load that pipe while populating routing, in BOM part no. shows blank.
Message 16 of 18
bradeneuropeArthur
Isn't my last post not clear.
You need to edit the family table.........
If help needed please let me know
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 18
maheshbhojkar
sorry for late reply......
Thank you for your precious help.....
i am adding new category & want to add parameters .....
But in drop down list no unit for sectional area(mm^2)
How can i add correct unit?
Message 18 of 18
maheshbhojkar
Need your support more on this.
Please explain what values should i put in designation?
