I don't find the Connectivity.InventorAddin.EdmAddin.dll for 2022.
Where can I find this library or What is the replacement in 2022?
Thomas
Solved by tcp_wegener. Go to Solution.
it moved to ""C:\ProgramData\Autodesk\ApplicationPlugins\VaultInventor2022.bundle\Contents\Connectivity.InventorAddin.EdmAddin.dll""
Have you installed the Vault SDK for 2022?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Yes, I have installed the Vault SDK 2022.
IMO the Connectivity.InventorAddin.EdmAddin.dll is installed with the Vault Client installation.
