Choosing open model for placing baseview?
適用対象外
561件の閲覧回数
7件の返信
メッセージ1/8
適用対象外
Hi all,
Currently, I have a code in a line for adding a baseview, it reads:
SyntaxEditor Code Snippet
oView1 = oSheet.DrawingViews.AddBaseView(oModel,oViewLoc, oViewScale, ViewOrientationTypeEnum.kLeftViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
Right now, for development purposes, I have oModel as a part document that is specified by a string for the pathname, i.e.
Dim oModel As PartDocument
Dim oModelName As String = "C:\Users\buntroh\Documents\Seal sleeve 2.ipt"
oModel= oDocs.Open(oModelName, False)
 However, I want to replace this string with the filepath of a part file that is open in the same collection of documents.
To clarify, just like how when you normally start a new drawing after finishing a part in a part file, the drawing automatically recognizes that 'newly created' model as the model to use when placing a new view. I just want to achieve the same thing (except since I am using iLogic to place the views, I have to specify the model document to use when placing the view).
Currently I have a rule that in my part document that is triggered when the user presses "Create Drawing". The rule prompts the user to save and then it opens up the drawing template. If theres a way to pass the newly created file path into my drawing document, that would be amazing.
0 件のいいね
解決済み
562件の閲覧回数
7件の返信
返信 (7)
メッセージ2/8
MechMachineMan
If you dont want the rule to be ran from the part document that you are going to make a drawing of, then when do you want it to be run?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
メッセージ3/8
適用対象外
I needed it to be run from the drawing document. I was under the notion that you can only run a rule that executes actions like placing base views and section views in a drawing document.
The only thing I need passed from the part document to the drawing document is the model/filepath itself.
0 件のいいね
メッセージ4/8
MechMachineMan
解決済み
True, but from the part doc you can Add a new drawing document based upon
the template you want to use and use ft hat mew document.
When you call it, you can also use is variable from there. Ie:
oDwgDoc = ThisApplication.Documents.Add (?,?)
Justin K
メッセージ5/8
適用対象外
Hmm... this actually helps a lot. I made this rule sometime ago, before I discovered the VB editor/object browser. Currently, I was using some weird VB command like system.diagnostics.process.start("filepath") to open my drawing template.
I still need your help though, because it is still not opening a new document with the "add" command. Here is what I have:
ThisApplication.documents.add(kDrawingDocumentObject, "STSH Standard 2015 experiment.idw", True)
0 件のいいね
メッセージ6/8
MechMachineMan
Give the full file location of the template rather than just the name.
Justin K
0 件のいいね
メッセージ7/8
適用対象外
Thank you so much!
Another quick question, whats the method to call the part file into a iLogic rule in my drawing doc? Say, if I want to use some of the part doc's parameters as variables in my drawing doc? As far as getting the file name/path of my part doc into my drawing doc goes, I think I know how to do that.
0 件のいいね
メッセージ8/8
MechMachineMan
oDoc = ThisApplication.Documents.ActiveDocument 'for use when you first
start rule in part doc
oDoc = ThisApplication.Documents.Documents.ItemByName (FullFileName)
Or
oDoc =ThisApplication.Documents.Open (FullFileName, BooleanVisibility) in
conjunction with oDoc. Releasereference / close
Justin K
0 件のいいね
