Change Text to Bold and Underlined
donaldleigh
donaldleigh
Morning all
I would like to be able to change the text of a multi value parameter to be bold, Italic and underlined in Ilogic
Here is the scenario:
This is for a large Threaded Stem.
In the Part File, if the user selects "Left Hand Thread" the text will be normal (This I can do)
But if the user selects "Right Hand Thread" I wish to have this bold, Italic and underlined
The Text will be used on a drawing in a Text leader
I'm guessing that I will have to have a rule within the drawing to control this. Is that right????
I have been able to work out how this is done for the view labels but I cant get it to work for the text label
Donald
MechMachineMan
Grab the assosciated LeaderNote, modify formatted text.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-0E649500-E267-4965-A0FB-3847CDB6349B
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
