change sected parts colour in an assembley
hi all,
I am trying to put a bit of code together to over ride the appearance colour of parts in an assembly.
we are using cable tray and we change the colour of the tray in one view rep to show if it is for power or signal, we also want everyone who works on the project to do it the same way (this is where iLogic come in)
I want to put together a button (for example 24v needing to be red) so you select the parts ( that could be in the top level or in sub-assemblies) and then click the button and the rule changes the appearance colour to red.
I have looked all over and seam to find different codes but none does or can be easily changed to do what I need
any help would be great.
Thank you
MechMachineMan
1. Post your sample code.
2. Post links of things that might be similar to what you want if you don't know how to code
'define the assembly
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
'define the appearance library
Dim oLib As AssetLibrary
oLib = ThisApplication.AssetLibraries("Autodesk Appearance Library")
'make sure colors are in assembly doc
Dim libAsset As Asset
libAsset = oLib.AppearanceAssets.Item("Smooth - Red")
Try
	localAsset = libAsset.CopyTo(oAssyDoc)
Catch
'catch error if it's already local
End Try
libAsset = oLib.AppearanceAssets.Item("Smooth - Black")
Try
Catch
End Try
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAssyDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
Dim oAsset As Asset
Dim oSS As SelectSet
oSS = oAssyDoc.SelectSet
Dim oSelCollection As New Collection
For Each oItem In oSS
	oSelCollection.Add(oItem)
Next
'set color overrides of components at the assembly level
For Each oOcc In oAsmCompDef.Occurrences.AllLeafOccurrences
	Dim MatchFound As Boolean = False
	For Each oItem In oSelCollection
		If oOcc.Equals(oItem) Then
			MatchFound = True
		End If
	Next
	If MatchFound = True Then
		oAsset = oAssyDoc.Assets.Item("Smooth - Red")
	Else
		oAsset = oAssyDoc.Assets.Item("Smooth - Black")
	End If
	oOcc.Appearance = oAsset
Next
 Edited by
Discussion_Admin
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
thank you,
first off sorry I didn't attach the code I already have
what you have done is grate.
I am still learning how to code,
I was wondering if you would be able to alter it to only change the selected part? and explain it to help me understand it better? ( at the moment it changes the selected parts red and the not selected parts back)
I have had a go changing it myself and have had mixed results.
Kind Regards
MechMachineMan
You are likely better off buying and reading a book on programming in vb.net or object oriented programming.
There are many blogs/guides/documents online as well.
Remove these 2 lines from the code to avoid setting everything else to black... As the "If/Else" construct implies....
	Else
Justin K
I thought that would do it as well but I get this error
Error in rule: change, in document: Assembly1
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
I have put a message box to check/ debug that it is not the rest of the code. all that works fine up until the message box ( I have commented it out.
Try
Catch
End Try
Try
Catch
End Try
Dim oAsset As Asset
Next
			MatchFound = True
		End If
	Next
	' this works fine till this point' MessageBox.Show("Message", "Title")
	End If
Next
Kind Regards
MechMachineMan
Ok, so if the code works good up until that point, you need to very careful examine everything that happens after.
In this case:
	End If
Next
What we set is that oASSET is assigned a value inside an if loop. If TRUE, the oASSET value gets assigned, if FALSE, the oAsset value isn't assigned. Look back through all of the code before this, and we see there is no default value assigned to the oASSET OBJECT.
If we look past the IF Statement, we see that the program is trying to assign the oASSET to an object, so of course it will fail.
There's really only 2 ways to fix it: ensure the oAsset variable DOES have a value when we try to assign it, or don't assign it.
We could add an if statement before the
line to ensure that the line is only run if  NOT (oAsset is Nothing)... but that would be redundant, since we can just move the line inside of the if loop that assigns the oAsset value.
Justin K
thank you for your help, in this it works when I put
inside the if statement.
Kind regards
