Inventor, scan files created with education version
matthias.schindler
matthias.schindler
Is there a way to scan inventor files with VBA to see, whether that created with an education version or not, and export in an CSV/TXT file to see the result?
If yes, please provide me a sample code.
I hope you understand what I try to say!
Many thanks!
Schindler Matthias
Technischer Produktdesigner/Anlagen- und Maschinenkonstruktion
technical productdesigner/ construction systems
| Socialnetwork LinkedIn
Umfrage zu "Inventor-HSM-Handbuch"
Eigener Artikel, wie man eine 30-seitige Testversion meines Inventor-HSM Handbuches bekommen kann
bradeneuropeArthur
With this:
Public Sub loopprop()
Dim a As Application
Set a = ThisApplication
Dim b As Document
Set b = a.ActiveDocument
Dim pr As Property
Dim ps As PropertySet
'LastUpdatedWith
For Each ps In b.PropertySets
Debug.Print ps.DisplayName
For Each pr In ps
If pr.DisplayName = "LastUpdatedWith" Then
MsgBox pr.Expression
' write this to text file..... End If 'Debug.Print pr.DisplayName & vbTab & pr.Expression Next Next End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
