Hello Everybody,
I am working on a samll project to automate the drawing of a cylindrical part (see attached picture). What I wish to do is place a section view of the part, but only one side of the section and not a complete view (picture).
I tried to add a crop to my section but i didn't manage to remove the crop (using iLogic) when dimensions of the part are changed. I also tried to do a halfway section but I was left with unwanted section lines (and I Don't know how to select them to change their visibilty).
Could you please advise me ?
Thanks in advance
Hello Everybody,
Thanks in advance
Is this what you need?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Arthur Knoors
Thank you @bradeneuropeArthur for your reply.
yes this is it.
I need to generate this "half" section view using iLogic and add dimensions to it (especially internal and external diameter).
Thank you in advance
yes this is it.
I did this in two steps without i-logic!
Would this be ok for you?
Arthur Knoors
Arthur Knoors
In fact I need to use ilogic to automate the process because there will be different parts with different dimensions. But you can share your solution maybe I can find a corresponding iLogic code.
