Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Autodesk Inventor 2024 taking old file reference for suppress parts.
pranaykapse1
pranaykapse1
I have an assembly(let's say "A") created using Skeleton (one part with multiple solid bodies in it, Assembly created using derived parts) modeling.
whenever I copy the design of this assembly(A), the suppressed parts take old file references only.
then I have to change the reference of suppressed parts manually every time for all suppressed parts of Assembly (B), which is too hectic for the user.
Then if I wanted to copy the design of Assembly B to Assembly C I could not possibly because Assembly B had old references in it, if I did not change the reference manually.
Please have a look into this issue.
Thanks & Regards
Pranay Kapse.
bradeneuropeArthur
This is one of the reasons I don't like the possibility to edit the Primairy/Master Model State:
https://forums.autodesk.com/t5/inventor-ideas/lock-the-quot-master-primary-quot-model-state/idi-p/12...
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
