Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Assembly Drawing title block material N/A
17 REPLIES 17
Message 1 of 18
andrew_canfield
3375 Views, 17 Replies
If a drawing template is used for a part the title block picks up the iproperty of the model's material.
The same drawing template is also  used for assemblies. Now the wish is for the title block to show "N/A" for material
How can the Properties - Model / Material iproperty be set to "N/A" when an assembly view has been placed?
Thanks for looking
Andrew
17 REPLIES 17
Message 2 of 18
in reply to: andrew_canfield
Hi @andrew_canfield
I just wrote this few lines of code for you.
Only paste it into an iLogic rule to make it work.
Dim oDrawDoc As DrawingDocument
	oDrawDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
	oSheet = oDrawDoc.ActiveSheet
Dim oView As DrawingView
For Each oView In oSheet.DrawingViews
    If oView.ReferencedDocumentDescriptor.ReferencedDocumentType = kAssemblyDocumentObject Then
        MessageBox.Show("Is an assembly")
    Else
        MessageBox.Show("Is not an assembly")
    End If
Next
It will check your drawing for views of .iam-files. Change the two MessageBox-lines to what you expect to happen in that specific case and trigger the rule with the open document event or whatever you like to .
I hope this will help you!
If you have further questions, please ask Smiley Wink
Message 3 of 18
Hi @andrew_canfield,
Can you please provide sample drawings which are linked part and assembly respectively?
Please make sure that files are non confidential one.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 18
Hello Chandra
The mapping is pretty simple, the template is used for parts and assemblies.
No problem for parts, but the template iproperty <material> is looking for a part - can it be swapped when an assembly is placed (or is there an alternative workflow- have two separate templates?)
The idea is for N/A to be displayed when an assembly is placed.
Regards
Andrew
Message 5 of 18
dgreatice
do you want to try hard way or easy way?
hard way with code, easy way with difference TitleBlocks (not difference template, just difference title block with easy naming for easy use).
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 6 of 18
dgreatice
in reply to: dgreatice
sorry, my clarification are if you edit that title block with hard way, if in 1 file there are many sheet, each sheet have difference base model (assemblys or parts), it cant be only use 1 titleblock, because that titleblock use for all sheet.
better way is create new titleblock for difference base model.
like A0 for Assy and A0 for part, then create sheet format for easy use when new sheet.
Message 7 of 18
andrew_canfield
My initial thought was a line of iLogic code.
thinking, If this, then replace.
But the part material doesn't exist so there's nothing to replace.
It's trickier than I thought.
Message 8 of 18
dgreatice
are in 1 file there are many sheet and with difference base model? if yes you cant edit or replace that title block attribute.
Message 9 of 18
andrew_canfield
This idea doesn't seem right but..
if the drawing contains an assembly
then..
Place the text "N/A" (need to format the size & font)
at co-ordinates to suit the paper size/title block.
Else..do nothing
I think I could do most of that!- not sure how to ensure the font is Arial 5mm.
Message 10 of 18
In any assembly file, Material iProperty is disabled. For more details, refer the following screenshot.
It is clear that, "Material" iProperty is unable for Assembly files.
But it is available for part files. refer the following screenshot of iProperty in part file.
That's why, In drawing file "Material" iProperty is able to link from part file.
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 11 of 18
Completely different approach!
Place "N/A" in the empty text box - just add it to the drawing:
still need to figure out how to set the font height
added this
 #Dim oStyle As TextStyle
   # oStyle = oGeneralNotes.Item(1).TextStyle
    #oStyle.FontSize * 3
which doesn't work!!
Making progress 🙂
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    ' Set a reference to the active sheet.
    Dim oActiveSheet As Sheet
  oActiveSheet = oDrawDoc.ActiveSheet
    ' Set a reference to the GeneralNotes object
    Dim oGeneralNotes As GeneralNotes
    oGeneralNotes = oActiveSheet.DrawingNotes.GeneralNotes
    Dim oTG As TransientGeometry
   oTG = ThisApplication.TransientGeometry
    ' Create text with simple string as input. Since this doesn't use
    ' any text overrides, it will default to the active text style.
    Dim sText As String
    sText = "N/A"
    Dim oGeneralNote As GeneralNote
   oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(92.3, 1.2), sText)
Message 12 of 18
It's a complete fudge but ...
    Dim sText As String
    sText = "N/A"
'    Dim oGeneralNote As GeneralNote
'   oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(92.3, 1.2), sText)
If ActiveSheet.Size= "A0" Then
	tx=92.64
	ty= 1.37
	   Else If ActiveSheet.Size= "A1"
   	tx=57.8
	ty= 1.37
	   Else If ActiveSheet.Size= "A2"
   	tx=33.2
	ty= 1.37
   End If
'   tx=92.64
'   ty= 1.37
oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(tx, ty), sText)
oGeneralNote.FormattedText = "<StyleOverride FontSize = '0.25'>" & sText & "</StyleOverride>"
Message 13 of 18
This can be done without coding:
  1. Create an custom I-property ie CompanyMaterial with the Expression "<N/A>" in the assembly templates. no = symbol
  2. Create an custom I-property ie CompanyMaterial with the Expression "=<Material>" in the part templates. with = symbol
    The material will be prompted in this property too.
  3. Go to the drawing  template and create an custom I-property ie CompanyMaterial.
  4. put one of the parts or assembly templates into your dwg template
  5. go tho the drawingdocument settings options and copy the iprop CompanyMaterial. to the drawing
  6. delete the parts or assembly from your drawing and save as template again.
  7. put a textbox or symbol in your drawing with the CompanyMaterial
  8. the assembly dwg will show <N/A>
  9. the part dwg will show the material
if help needed please let me know
Arthur Knoors
Autodesk Affiliations:
Message 14 of 18
Thanks, I think I follow..
could I have a screen shot of:
I'm thinking the drawing take the iproperty from the .iam template?
The iam template takes the iproperty from a part (custom property n/a)
When the parts are deleted aren't the links lost?
Ongoing...
Message 15 of 18
what screenshot do you need.
the links are not links in terms of links.
so they are deleted after part or assembly removal.
Arthur Knoors
Message 16 of 18
ScreenShot part:
Screenshot Assembly:
The Assembly uses fix text as <N/A> for Companymaterial
the part used =<material> for Companymaterial
Then copy the property "Companymaterial" into the drawing via the document settings:
Screenshot is in previous post.
Arthur Knoors
Message 17 of 18
One slight hitch.
90% of the assemblies have been created, the fix is to add the new CompanyMaterial N/A iproperty  (I think)
Regards
Andrew
Message 18 of 18
Or put a default value in your drawing property n/a
Arthur Knoors
