Dear all,
A month ago we changed from Inventor 2012 to Inventor 2017. One negative thing we've noticed. When deriving the work geometry of a part, it is not alphabetically sorted anymore. Is there a way to change this?
Kind Regards,
Hi.
With programming Yes.
Otherwise I see no option to achieve this.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Thanks for your comment. I spoke with Autodesk and it is a bug. They are planning to fix this (Hopefully with a hotfix)
See the same behavior in 2018 of inventor.
So if they are willing to solve this ........
Arthur Knoors
