Hi everyone,
yes, like my topic. I also read many topic about this, but i am stilling stuck on it, mybe too much way.
I can create a ribbon, panel, and add button on it.
But i dont know how to put an icon for that button. Somebody help me please.
This is my current fail code.
Dim oStream1 As System.IO.Stream = Me.GetType().Assembly.GetManifestResourceStream("Inventor_Sheet.favicon4.ico") Dim oIcon1 As Drawing.Icon = New Drawing.Icon(oStream1) Dim oIPictureDisp1 As Object = AxHostConverter.ImageToPictureDisp(oIcon1.ToBitmap()) Dim oCtrlDefs As ControlDefinitions = oinv.CommandManager.ControlDefinitions Dim oButtonDef As ButtonDefinition = oCtrlDefs.AddButtonDefinition("Doi sheet", "btn_doisheet", CommandTypesEnum.kQueryOnlyCmdType, "AddInGuid", "Description", "Tolltip text", oIPictureDisp1, oIPictureDisp1, ButtonDisplayEnum.kDisplayTextInLearningMode)
Thank you
Solved by bradeneuropeArthur. Go to Solution.
For which version of inventor?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
then use This:
Imports Inventor Imports System.Runtime.InteropServices Imports Microsoft.Win32 Imports VB = Connectivity.Application.VaultBase Imports System.Collections.Generic Imports AuCoWebs = Autodesk.Connectivity.WebServices Imports Autodesk.Connectivity.WebServices Namespace gggg_ <ProgIdAttribute("gggg"), GuidAttribute("gggg")> Public Class StandardAddInServer Implements Inventor.ApplicationAddInServer Private WithEvents m_uiEvents As UserInterfaceEvents Private WithEvents m_InvAppEvents As Inventor.ApplicationEvents Private WithEvents m_sampleButton As ButtonDefinition #Region "ApplicationAddInServer Members" ' This method is called by Inventor when it loads the AddIn. The AddInSiteObject provides access ' to the Inventor Application object. The FirstTime flag indicates if the AddIn is loaded for ' the first time. However, with the introduction of the ribbon this argument is always true. Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate ' Initialize AddIn members. g_inventorApplication = addInSiteObject.Application ' Connect to the user-interface events to handle a ribbon reset. m_uiEvents = g_inventorApplication.UserInterfaceManager.UserInterfaceEvents m_InvAppEvents = g_inventorApplication.ApplicationEvents '' TODO: Add button definitions. '' Sample to illustrate creating a button definition. Dim largeIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.Rev) Dim smallIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.YourSmallImage) Dim controlDefs As Inventor.ControlDefinitions = g_inventorApplication.CommandManager.ControlDefinitions m_sampleButton = controlDefs.AddButtonDefinition("Command Namex", "Internal Namex", CommandTypesEnum.kShapeEditCmdType, AddInClientID) #Region "Image Converter" ' Class used to convert bitmaps and icons from their .Net native types into ' an IPictureDisp object which is what the Inventor API requires. A typical ' usage is shown below where MyIcon is a bitmap or icon that's available ' as a resource of the project. ' ' Dim smallIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.MyIcon) Public NotInheritable Class PictureDispConverter <DllImport("OleAut32.dll", EntryPoint:="OleCreatePictureIndirect", ExactSpelling:=True, PreserveSig:=False)> _ Private Shared Function OleCreatePictureIndirect( _ <MarshalAs(UnmanagedType.AsAny)> ByVal picdesc As Object, _ ByRef iid As Guid, _ <MarshalAs(UnmanagedType.Bool)> ByVal fOwn As Boolean) As stdole.IPictureDisp End Function Shared iPictureDispGuid As Guid = GetType(stdole.IPictureDisp).GUID Private NotInheritable Class PICTDESC Private Sub New() End Sub 'Picture Types Public Const PICTYPE_BITMAP As Short = 1 Public Const PICTYPE_ICON As Short = 3 <StructLayout(LayoutKind.Sequential)> _ Public Class Icon Friend cbSizeOfStruct As Integer = Marshal.SizeOf(GetType(PICTDESC.Icon)) Friend picType As Integer = PICTDESC.PICTYPE_ICON Friend hicon As IntPtr = IntPtr.Zero Friend unused1 As Integer Friend unused2 As Integer Friend Sub New(ByVal icon As System.Drawing.Icon) Me.hicon = icon.ToBitmap().GetHicon() End Sub End Class <StructLayout(LayoutKind.Sequential)> _ Public Class Bitmap Friend cbSizeOfStruct As Integer = Marshal.SizeOf(GetType(PICTDESC.Bitmap)) Friend picType As Integer = PICTDESC.PICTYPE_BITMAP Friend hbitmap As IntPtr = IntPtr.Zero Friend hpal As IntPtr = IntPtr.Zero Friend unused As Integer Friend Sub New(ByVal bitmap As System.Drawing.Bitmap) Me.hbitmap = bitmap.GetHbitmap() End Sub End Class End Class Public Shared Function ToIPictureDisp(ByVal icon As System.Drawing.Icon) As stdole.IPictureDisp Dim pictIcon As New PICTDESC.Icon(icon) Return OleCreatePictureIndirect(pictIcon, iPictureDispGuid, True) End Function Public Shared Function ToIPictureDisp(ByVal bmp As System.Drawing.Bitmap) As stdole.IPictureDisp Dim pictBmp As New PICTDESC.Bitmap(bmp) Return OleCreatePictureIndirect(pictBmp, iPictureDispGuid, True) End Function End Class #End Region End Module
Arthur Knoors
Thank you for your help,
After create class "PictureDispConverter"
I have an error in GUIDline : value of type"Guid" can not to GUID. How do I solve this ?
After having that class, i use like this, right ?:
Dim mIPictureDisp1 As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.ico_1)
I have an icon 24x24 .bmp which be named : ico_1
I am far from my desk.
Earliest monday morning I am able to take a closer look.
Regards
Arthur Knoors
Thank you,
I also work follow help API, but result also like this image....
This is my current code
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load Dim oDoc As Document = oinv.ActiveDocument Dim oUIMNG As UserInterfaceManager = oinv.UserInterfaceManager 'Get ribbon Tab Dim oMy_ribbon_group As Inventor.Ribbon = oUIMNG.Ribbons.Item("ZeroDoc") For Each oribbon_trung As RibbonTab In oMy_ribbon_group.RibbonTabs If oribbon_trung.InternalName = "id_BuildTab" Then oribbon_trung.Delete() End If Next Dim oMy_ribbonTab As RibbonTab ' Try oMy_ribbonTab = oMy_ribbon_group.RibbonTabs.Add("BuildTab", "id_BuildTab", "{5B9AA8AD-1D99-4957-8CB4-9870F23CBBFH}", "id_TabTools", True, False) 'Catch ex As Exception 'MsgBox(ex.Message) 'End Try 'Get panel For Each opanel_trung As RibbonPanel In oMy_ribbonTab.RibbonPanels If opanel_trung.InternalName = "id_doitensheet" Then opanel_trung.Delete() End If Next Dim onew_panel As RibbonPanel = oMy_ribbonTab.RibbonPanels.Add("Đổi tên sheet", "id_doitensheet", "Addanaddinid", "", False) Dim ocontrl_def As ControlDefinitions = oinv.CommandManager.ControlDefinitions Dim smallPicture As stdole.IPictureDisp = PictureConverter.ImageToPictureDisp(My.Resources.Image1) Dim largePicture As stdole.IPictureDisp = PictureConverter.ImageToPictureDisp(My.Resources.Image2) Dim obutton_def As ButtonDefinition = ocontrl_def.AddButtonDefinition("Check btn", "id_checkbtn", CommandTypesEnum.kNonShapeEditCmdType, "{311a4c02-49df-4947-a01c-47765ec06b27}", "Chekc descrip", "Check tooltip", , ) obutton_def.StandardIcon = PictureConverter.ImageToPictureDisp(My.Resources.Image1) obutton_def.LargeIcon = PictureConverter.ImageToPictureDisp(My.Resources.Image2) onew_panel.CommandControls.AddButton(obutton_def, True, True,,) End Sub End Class '--------------------------- '--------------------------------------------------------------------------------------------------------------------------------- <System.ComponentModel.DesignerCategory("")> Friend Class PictureConverter Inherits System.Windows.Forms.AxHost Private Sub New() MyBase.New(String.Empty) End Sub Public Shared Function ImageToPictureDisp( ByVal image As System.Drawing.Image) As stdole.IPictureDisp Return CType(GetIPictureDispFromPicture(image), stdole.IPictureDisp) End Function End Class
try it this way:
' This function uses reflection to get the GuidAttribute associated with the add-in. Public Function AddInClientID() As String Dim guid As String = "" Try Dim t As Type = GetType(KnoorsInventorTools__Tester191202_.StandardAddInServer) Dim customAttributes() As Object = t.GetCustomAttributes(GetType(GuidAttribute), False) Dim guidAttribute As GuidAttribute = CType(customAttributes(0), GuidAttribute) guid = "{" + guidAttribute.Value.ToString() + "}" Catch End Try Return guid End Function
Arthur Knoors
