In parts & assemblies, I can add a multi-value parameter, add it to a form & select the value from there.
I want to do the same thing in a drawing.
Is this possible?
Solved by bradeneuropeArthur. Go to Solution.
You can also add parameters to a drawing yes.
So that means this should be possible.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Parameters are also available within the drawing.
So you can use the same principle.
Arthur Knoors
Arthur Knoors
