Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
2D Template: Total value from BOM
5 REPLIES 5
374 Views, 5 Replies
I would like the total value from my Chain Length Column on my BOM. Is there way to do that
I know it's 14454 mm, but i'd be nice if it could just "spit it out" automatically
5 REPLIES 5
bradeneuropeArthur
Could you please explain a little more, since I don't understand what you mean?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
in reply to: bradeneuropeArthur
No/Pos 12 has a value of 2454 mm. No/Pos 13 a value of 12000 mm. Combined 14454 (Under Chain Length)
How do I make Inventor calculate the vaule from the CHAIN LENGTH column and give me the total sum
bradeneuropeArthur
can you send the dwg file, so I can show you how?
Arthur Knoors
Here you go
bradeneuropeArthur
could you send a pack and go.
Ipt and Iam files are missing.
Arthur Knoors
Technology Administrators
